Arcgis Arcade script file extension
1757
08-20-2022 10:13 PM
GuyShaharabani
Hi!
I want to use arcade in a separated file in order to debug it.
is it possible? if so, what file extension the script file should have?
Thank you all!
JohannesLindner
Related:
Use IDE for writing Arcade expressions - Esri Community
Tips for debugging Arcade scripts in VSCode/Node.j... - Esri Community
You can use external IDEs to get a nice syntax highlighting, but you probably won't be able to really debug it, since many Arcade functions (especially the FeatureSetBy*() functions) are specific to the ArcGIS environment.
For me, the best way to test and debug is either the Playground | ArcGIS Arcade | ArcGIS Developers or a testing dashboard loaded with the data I actually work with.
Have a great day!
Johannes
