ArcGis API for Javascript 4.12 - TimeSlider Widget
6243
13
11-17-2019 11:15 PM
IanMagero
I am using the timeslider widget but I am experiencing some challenge with it.
I am getting my data from a GeoJsonLayer which is filtered when a user selects an option from a dropdown.
The first time the dropdown is selected the time slider displays correctly:
However when a user selects another option from the dropdown the timeSlider appears as below:
I have tried to set the view to null to no avail.
What can the issue be which is making the timeSlider not render correctly ?
IanMagero
Hi Undral Batsukh
I have managed to come up with a codepen:
https://codepen.io/IanMagero/project/editor/XrywoY
It clearly depicts how I have written my logic and clearly shows how the TimeSlider is rendered when the select option is changed:
Please note when a select option is selected the map(earthquake_depth) is executed and this function is what has the map logic:
$( document ).ready(function() {
$(document).on('change','#earthquake_depth select',function(){
var earthquake_depth = $(this).val();
map(earthquake_depth);
IanMagero
There is no error in the console
IanMagero
Below is the code:
const timeSlider = new TimeSlider({
container: "timeSlider",
playRate: 1000,
view: view
view.ui.add(timeSlider, "manual");
view.whenLayerView(geojsonLayer).then(function(lv) {
layerView = lv;
const start = geojsonLayer.timeInfo.fullTimeExtent.start;
timeSlider.fullTimeExtent = {
start: geojsonLayer.timeInfo.fullTimeExtent.start,
end: geojsonLayer.timeInfo.fullTimeExtent.end
const end = new Date(start);
var year = end.getFullYear();
var month = end.getMonth();
var day = end.getDate();
var next_yr = new Date(year + 1, month, day)
//end.setDate(end.getDate() + 1);
timeSlider.values = [start, next_yr];
timeSlider.createStopsByInterval(
timeSlider.fullTimeExtent,
value: 1,
unit: "years"
timeSlider.watch("timeExtent", function(event) {
geojsonLayer.definitionExpression = "time <='"+timeSlider.timeExtent.end.getTime()+"'AND select_option ='"+select_option_val+"'";
layerView.effect = {
filter: {
timeExtent: timeSlider.timeExtent,
geometry: view.extent
excludedEffect: "grayscale(20%) opacity(12%)"
IanMagero
Hi all,
I resolved this issue.
What I did is I rewritten the whole logic again and used feature layer instead of Geojson layer and the timeslider worked like charm.
Thanks for those who tried to assist me.
Thanks Undral Batsukh
