ArcGis 4.27 - CIM hitTest is NOT CORRECT - Feature's click area is too large
2250
06-26-2023 06:50 AM
michaelpoa
The CIM symbol's click area is too large when using CIMTextCymbols. When you click outside the icon's view area, the feature is still present in the hitTest results. So I assume it does not respect the frame with an icon font?
Reproduce:
Codepen: https://codepen.io/michaelk95/pen/poQReYy?editors=1000
@AnneFitz CIM related?
Thanks
UndralBatsukh
Hi there,
So we just fixed this issue and you will be able to test it out on our next version. Here is your app pointing to next version: https://codepen.io/U_B_U/pen/ExOWVgr?editors=1000
-Undral
UndralBatsukh
Hi there,
I am able to see the behavior you describe and we will be looking into improving hittest behavior to get the closest hit. I will update you once we update the hittest behavior.
michaelpoa
Thanks in advance!
I only see the issue with CIMTextSymbol related renderers.
For new releases it would be nice if you could change the tolerance for the hitTest?
michaelpoa
Is this fixed in api v4.28 ? @UndralBatsukh
UndralBatsukh
Hi there,
-Undral
