Arcade popup div
847
11-04-2024 11:04 AM
Paco
Hello all!
I am struggling with adding Arcade to a simple custom div popup in a javascript 4.x build?  should be simple?
the Arcade script works within an AGOL mapview, but I must be missing something trying to add it to my js.  I am accessing the FeatureLayer directly, independent of a mapview.
actually,  I am having trouble adding 'anything' to the div beyond simple html text.
I am trying to get the contents of a source Field to show in the div 'popup',  and it does not recognize "$feature".   The actual Arcade is somewhat irrelevant,  it's the process of getting the js to recognize the Arcade statement,  and getting that output into the html div.
This is actually a popup that is triggered by a Sources click inside an existing popupTemplate.  see screenshot and pieces of the code below-
*THE POPUP*
        <div id="popupSources">
            <p>Links to Sources</p>
            <button class="popupSourcesClose" onclick="closePop()">
                <p>Close</p>
            </button>
        </div>
      <script>
        function closePop() {
            const popClose =
                document.getElementById(
                    "popupSources"
                popClose.style.display = "none";
        function openPop() {
          const popOpen =
                    "popupSources"
                popOpen.style.visibility = "visible"
                popOpen.style.display = "block"
                console.log("OPEN")
      </script>
*THE ARCADE*
 <script>
          var feat = $feature.DataSourceID
          var table = FeatureSetByName($datastore, "GHS_DataSources_DataRelease_v1_Service", ['DataSources_ID', 'URL'], false)
          var arr = Split(feat, " | ")
          var output = []
          for (var index in arr) {
            var dsource = arr[index]
            var pub = Filter(table, "DataSources_ID = @dsource")
            var link  = `<a href="${First(pub).DataSources_URL}">${dsource}</a>`
            Push(output, link)
          return {
            type : 'text',
            text :
            <b>Data Source:</b> ${Concatenate(output,' - ')}<br><br>
        </script>
Paco
..or possibly use a popupTemplate within a popupTemplate instead of html div?  not sure if that's possible from the click within the first popup tho..
