Arcade expression that returns the "Maximum" value, but excludes NULL values.
6352
01-07-2017 06:59 AM
Guidovan_der_Kolk2
I'm trying to use Arcade to create labels that show the highest value from a number of fields.
  • Field 1 (number field) contains the value -2.7
  • Field 2 (number field) contains the value -2.5
  • Field 3 (number field) is empty (NULL)
If I use the following expression:
Max (Field1, Field2, Field3)
I get "0" as a result, when I expect to get -2.5 as a result. How can I create an expression that ignores the NULL/empty field?
PaulBarker
Sorry for the slow reply.  For math operations nulls will be returned as zeros.  My recommendation would be to test the variable for null values before evaluating and substituting it if need be for something you know will not impact the expression.  It might look something like this:
MAX(IIF (isEmpty($feature.Field1),-9999,$feature.Field1),IIF (isEmpty($feature.Field2),-9999,$feature.Field2),IIF (isEmpty($feature.Field3),-9999,$feature.Field3))
SharonUngerer_DNREC
I like the making it negative -999. Very simple way to remove it from MAX function
