arcade expression notworkig
674
02-12-2025 01:33 PM
anonymous55
I have this code for a popup, and part of it includes an arcade expression to change the value, but my code is not working. I’m just starting to learn JavaScript right now, so I’m not very advanced in it. Thanks!
//popup for Intersection
  const IntersectionPopupTemplate = {
    // You can dynamically set the title, e.g., the block's name
    title: "Holiday Embargo (Intersection)",
    content: [
        type: "fields",
        fieldInfos: [
            fieldName: "OnStreetName",
            label: "Cross Street 1"
            fieldName: "FromStreetName",
            label: "Cross Street 2"
            fieldName: "BoroughCode",
            label: "Borough",
            format: {
              expression: `
                var borough = $feature['BoroughCode'];
                return (borough == "M") ? 'Manhattan' :
                       (borough == "X") ? 'Bronx' :
                       (borough == "B") ? 'Brooklyn' :
                       (borough == "Q") ? 'Queens' :
                       (borough == "S") ? 'Staten Island' : 'n/a';
KenBuja
Use the When function instead of the ternary operator
When(borough == "M", 'Manhattan',
     borough == "X", 'Bronx',
     borough == "B", 'Brooklyn',
     borough == "Q", 'Queens',
     borough == "S", 'Staten Island',
     'n/a')
