arc-jsapi How can I st_geometry using a lookup field?
2818
06-13-2016 01:38 AM
ParkSeungHyun
I am using the st_geometry field and try to view the PNU code value.
I tried two ways.
1. oracle DB query.
    select a.pnu from LP_PA_CBND_4600000000 a
    where sde.st_contains(a.shape,
    sde.st_point(177566.6728471977,160430.12935426735, 4))=1
When an event occurs, click the map object
i got the  evt.mapPoint(x,y).
4 is my srid.
this way is took a long time. and query was down...
2. i used the arcgis api`s IdentifyParameters
my code is follows.
      PoiClick : function(map, evt) {
        G_evt =evt;
        console.log("ClickPoint ==== "+evt.mapPoint);
        var targetLayerId = 'LP_PA_CBND';
        var url = map.Layers.getLayerInfo(targetLayerId).SVC_URL;
        var map = map.getMap();
        //파라미터 설정.
        var idParams = new krcgis.core.tasks.IdentifyParameters();
        G_idparams =idParams;
        idParams.geometry = evt.mapPoint;
        idParams.mapExtent = map.extent;
        idParams.returnGeometry = true;
        idParams.tolerance = 3;
        idParams.layerOption = krcgis.core.tasks.IdentifyParameters.LAYER_OPTION_ALL;
        idParams.width = map.width;
        idParams.height = map.height;
           krcgis.Function.GetPoiInfo(url, idParams);
           return evt.mapPoint;
        //POI 정보를 가져온다.
        GetPoiInfo : function(url, idParams) {
         idTask = new krcgis.core.tasks.IdentyfyTask(url);
        idTask
        .execute(idParams)
        .addCallback(function (response) {
               G_response = response;
        if (response) {
        return response;
        .addErrback(function (error) {
        console.log('GetPoiInfo result error=', error);
It could be obtained in this way code pnu.
However, this way is different from the value that gets pnu code depending on the zoom level.
I want to get a single pnu code in a single x, y values.
how to get pnu code?
Database table  :
RobertScheitlin__GISP
Park,
  You should use the QueryTask for this:
QueryTask | API Reference | ArcGIS API for JavaScript
Query data without a map | ArcGIS API for JavaScript
Select with Feature Layer | ArcGIS API for JavaScript
The Query Class allows you to specify a query geometry and a spatial relationship, along with which fields you want returned.
ParkSeungHyun
Thanks~! your answer
