Applying featureReduction to GraphicsLayers
167
07-15-2025 10:58 AM
RyanMotamen
Hello, I am working in Esri Javascript SDK 4.32 and have a question. I am looking to implement clustering in client-side graphics using GraphicsLayers.
I have seen that there exists a property named featureReduction on FeatureLayers that enables clustering but this does not exist on GraphicsLayers.
I am wondering if there is an established solution for enabling clustering for GraphicsLayers or if this will require a more customized solution. Thanks!
JonathanDawe_BAS
An option might be to populate a feature layer with client side graphics and then use the rendering options?
This is the guidance Esri gives
It is generally preferred to construct a FeatureLayer with its source property when working with client-side graphics. The FeatureLayer performs better with larger datasets and has more capabilities, including rendering, querying, and labeling.
JonathanDawe_BAS
