applyEdits and AttributeInspector
2519
11-16-2015 02:28 PM
BC
I am trying to move a point of featureservice based on user click but lost on how to use attributeInspector to update a field value for that point.
Any ideas or suggestions?  Thank you in advance.
map.on("click", function(evt){
     if (functionMode == "3"){
      var selFeatures = flAddressPoints.getSelectedFeatures();
      var targetGraphic = selFeatures[0].setGeometry(evt.mapPoint);
      flAddressPoints.applyEdits(null,[targetGraphic],null,function(feature){
     } else if (functionMode == "1") {
     alert("aaa");
     } else {
     //alert("bbb");
BC
In other words, I am trying to create a tool where user will be able to:
1. select a record from featuretable and move the corresponding pt to map click location.  This part I working great.
2. After the pt is moved, I would like attributeInspector to open so user can change a value of a column.  This is where I am stuck.  Any suggestions?  Thank you.
by Anonymous User
Not applicable
Here is a sample that uses the Attribute Inspector: Using the attribute inspector | ArcGIS API for JavaScript
That might help you get some code started and if you run into issues you could post it here.
