API v2.6 breaks Bing maps backgrounds?
4707
22
12-14-2011 12:38 PM
StephenLead
Honored Contributor
I have a page which works correctly using v2.5 of the API. If I replace the API version with "2.6" in the lines:
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.6/js/dojo/dijit/themes/claro/claro.css">
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.6"></script>
the map loads correctly, and my FeatureLayers and DynamicLayers are displayed - but the Bing maps backdrop is missing.
If I revert to 2.5 in these two lines, Bing maps appears.
Any clues?
Steve
StephenLead
Honored Contributor
Hi Ed,
I'm not sure if we're talking about the same thing here?
I mean that if my HTML page, JS scripts (etc) are stored on my laptop, Bing won't show when I open the map. If I copy the whole set of code (otherwise untouched) onto a web server, Bing suddenly shows.
This isn't reproducible with the simple samples, so there's evidently something more complicated going on.
Anyway, it's not a show-stopper for me. As a workaround I can test locally using v2.5, then make the change to 2.6 when uploading to the web server.
Cheers,
Steve
EdSaunders
Steve, yeah I'm currently holding the wrong end of the stick.  I thought you meant you had downloaded a copy of the API.
StephenLead
Honored Contributor
This seems to be fixed using v2.7
