API v2.6 breaks Bing maps backgrounds?
4604
22
12-14-2011 12:38 PM
StephenLead
Honored Contributor
I have a page which works correctly using v2.5 of the API. If I replace the API version with "2.6" in the lines:
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.6/js/dojo/dijit/themes/claro/claro.css">
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.6"></script>
the map loads correctly, and my FeatureLayers and DynamicLayers are displayed - but the Bing maps backdrop is missing.
If I revert to 2.5 in these two lines, Bing maps appears.
Any clues?
Steve
derekswingley1
Our sample to add a bing layer works:  http://help.arcgis.com/en/webapi/javascript/arcgis/demos/ve/ve_layer.html
Post more code to repro?
StephenLead
Honored Contributor
Yeah I saw that sample was working. My code is pretty convoluted so I'll do some internal debugging first.
When you updated the samples, did you simply find/replace 2.5 with 2.6 in the Bing sample?
Steve
derekswingley1
Essentially, yes. The samples are updated with a batch find/replace process.
JeffMitzelfelt
I appear to have the same problem. I'm using the BasemapGallery Dijit in my application. All the services display except the Bing services. (All the services appear in the dijit but when one of the Bing services is click the basemap is blank.) I checked and the BasemapGallery samples (Default and Dropdown button use Bing) are working correctly.
derekswingley1
Can you post the code for your app? A simplified repro case would be preferred.
JeffPace
What kind of errors are you guys getting in firebug/fiddler? I am not seeing any
I use both the Basemap gallery Widget and the custom Basemap Control widget,
Bing maps display, but if i "clickwheel" or use the zoom slider to zoom, it looks like Basemaps never update.
The same layer chosen without the basemap gallery works fine.
The same layer chosen from BAsemap Control sample works fine.
Looks like a bug in the Basemap gallery that is not working with the new zoom style .
KellyHutchins
Esri Notable Contributor
Are you specifying a valid bing maps key for the BasemapGallery?
var basemapGallery = new esri.dijit.BasemapGallery({
  showArcGISBasemaps: true,
  bingMapsKey:'Enter Bing Maps Key Here',
  map: map
}, "basemapGallery");
JeffPace
  map: map
Yes I am.  To be more specific (or general)
1. Normal tiled services work fine
2. ANY basemap added via the basemap gallery (local, AGO, BING) all fail on mousewheel/zoom slider, its as if the "draw at new scale" is never received.  Operational layers on top of basemap draw fine.
3. If you switch layers the basemap will draw at the appropriate scale, so its only zoom events that are failing.
KellyHutchins
Jeff,
I can't reproduce with this sample:
http://help.arcgis.com/en/webapi/javascript/arcgis/demos/widget/widget_basemap.html
Can you repro with that sample? If so can you provide me with a series of steps that will show the problem. I tested switching basemaps and using the scroll wheel to zoom and everything looked ok to me.
