API v 1.7 nls strings
1699
08-14-2012 08:04 AM
RaviKonaparthi
Can anyone help me in how to use nls folder in custom widget implementation. When i am trying to point the nls folder it is referring to the AGS JS API (http://serverapi.arcgisonline.com/jsapi/arcgis/3.1compact/js/dojo/dojo/com/esri/template/nls/localiz...)
Here is how i am implementing nls:
require(["esri/map", "dojo/i18n"],
function (map, i18nStrings) {
          dojo.requireLocalization("com.esri.template", "localizedStrings");
          var nlsStrings = dojo.i18n.getLocalization("com.esri.template", "localizedStrings");
Any my nls file content is
    "outsideArea": "You are currently outside the supported area",
    "geoLocationTimeOut": "Timeout exceeded. Unable to perform the operation",
    "positionUnavailable": "Position unavailable",
    "permissionDenied": "Permission denied to locate current location",
Regards,
Ravi.
KellyHutchins
Esri Notable Contributor
Hi Ravi,
Sounds like you are trying to create a localization file for a custom widget? If so it might help to download the code associated with the Elevation Profile Template. This template includes a custom widget that calculates the elevation profile - to see the widget code check out the files in the apl folder.
http://www.arcgis.com/home/item.html?id=3b65b141041044ca97d83eb8264da08c
RaviKonaparthi
Hi Kelly,
Thank you. The sample worked. But just want to check is there any way to load the nls strings using dojo AMD loader?
Regards,
Ravi.
