API 4.33 error, basemapGallery.destroy() generates error.
1113
09-09-2025 03:58 AM
Wimvan_Dijk
In my code I dynamically add a basemapGallery:
basemapGallery = document.createElement('arcgis-basemap-gallery');
basemapGallery.position = "bottom-right";
mapDiv.appendChild(basemapGallery);
I remove the basemapGallery by pressing a button:
if (basemapGallery.destroy && typeof basemapGallery.destroy === 'function') { basemapGallery.destroy(); }
basemapGallery = null;
Using API 4.32 this works when I use the imports:
<link rel="stylesheet" href="/arcgis_js/javascript/4.32/esri/themes/light/main.css">
<script src="/arcgis_js/javascript/4.32/init.js"></script>
<script type="module" src="https://js.arcgis.com/map-components/4.32/index.js"></script>
But when I use the API 4.33 imports, I get an error on basemapGallery.destroy():
<link rel="stylesheet" href="/arcgis_js/javascript/4.33/esri/themes/light/main.css">
<script src="/arcgis_js/javascript/4.33/init.js"></script>
<script type="module" src="https://js.arcgis.com/map-components/4.33/index.js"></script>
The error is:
Uncaught (in promise) TypeError: can't access property "state", this.source is undefined
    render https://js.arcgis.com/4.33/map-components/6HFQH2MH.js:4
    update https://js.arcgis.com/4.33/map-components/M5H3TSRA.js:6
    performUpdate https://js.arcgis.com/4.33/map-components/M5H3TSRA.js:6
    scheduleUpdate https://js.arcgis.com/4.33/map-components/M5H3TSRA.js:6
    _$EP https://js.arcgis.com/4.33/map-components/M5H3TSRA.js:6
    requestUpdate https://js.arcgis.com/4.33/map-components/M5H3TSRA.js:6
    set https://js.arcgis.com/4.33/map-components/M5H3TSRA.js:6
When I change the last import line to version 4.32 it works without the error
Is there something I overlooked or is this an API error?
AnneFitz
Hi @Wimvan_Dijk - this is an API error. We have a fix that will be released with version 4.34 next month.
If you want to test out the fix ahead of the release, you can do so on our development version of the CDN:
https://js.arcgis.com/next
https://js.arcgis.com/next/map-components/
Note that as of 4.33, there is a new CDN endpoint for components where the version number comes before the component package for consistency with the core API CDN! See https://developers.arcgis.com/javascript/latest/release-notes/#new-cdn-endpoint-for-components for more info.
AnneFitz
Wimvan_Dijk
Thank you, appreciated!
