API 3.7 - Dnd Movable AMD Style
1831
10-30-2013 01:51 PM
CurtisSpurlock
I am using a movable object in my application.  Here is the code:
dnd = new Moveable(dom.byId("divDragPanel"), { handle: "imgDrag", skip: true });
I want to set up an event listener for the onMove event of the Moveable object.
If I set it up the legacy way it works fine:
    dojo.connect(dnd, "onMove", function (e) {
        //do something
When I try to set it up AMD style it does not work:
    on(dnd, "onMove", function (e) {
         //do something
Any ideas?
NumaGremling
When converting from Legacy to AMD, the �??on�?� in event names is taken out, as well as the element the event is connected to.
For example:
dojo.connect(mainMap, "onClick", findParcel);
would change to:
mainMap.on("click", findParcel);
I�??m not sure about the onMove event but try this:
dnd.on("move", function (e){
CurtisSpurlock
Thanks BritishSteel!  I tried your code but it did not work.
JamesVillanueva
Try to change it to this:
on(dnd, "move", function (e) {
//do something
