Any way to hide an infoWindow on a mouse click?
6685
16
05-13-2012 08:21 AM
JayGregory
Was curious if anyone's found a way to hide an infoWindow when a user clicks outside the infoWindow (instead of having to click the "x" or click on another map graphic which displays another infoWindow.
I tried setting a dojo.connect event handlers like dojo.connect(map, "onClick", map.infoWindow.hide()); but that doesn't seem to work.
Thanks!
Jay
DavidTreering
Still not working.  Is a polygon tiled layer used as a basemap considered a graphic?  Or only the dynamic feature layer?
StephenLead
Honored Contributor
Hi David,
No, a tiled or dynamic layer isn't considered a graphic. A feature layer is, as is a graphics layer, or a single graphic.
Can you post your whole code, or a link to your site?
Cheers,
Steve
DavidTreering
Steve, Here's my code...this is a work in progress.  Not everything works.  Please let me know if my services are coming through alright or if you cannot see them load.
David
DavidTreering
I'll also want to hide the infoWindow if scale changes beyond the visible scale range for the layer.   Hmmmm.
I appreciate your time, and any ideas would be a great help.
DavidTreering
I've tried opening it up.  Can you try again?
StephenLead
Honored Contributor
Hi David,
I think the map's onClick handler isn't being initiated because it's not sitting inside a function. Try moving that listener immediately underneath the map declaration (eg around line 368).
This is a bit trickier since the API doesn't directly tell you whether a layer is "on but outside its scale range". See the post here for some pointers you may be able to use.
You may need to hard-code something in your code, then check the current scale range on each zoom change.
Good luck,
Steve
DavidTreering
That worked, thanks!
I'll try to
, and post what I do.  I'll probably choose to store variables rather than send a query every onZoomChange.
