Any templates to perform topology checks/correction in client side?
1781
08-02-2016 02:22 PM
KushendraShah1
I have created a javascript webmap that has editing functionality. I want user to edit/create new features on-screen but meanwhile set up and keep default topology correction on the client. Is there way I can integrate topology correction/validation while user completes the editing feature? for eg. If I create a new property boundary that accidentally draw on the other property boundary, then it should auto snap with the vertices or line of the other property boundary- keeping the topology rule (that polygons must not overlapped) while editing mode.
Any samples or templates or link associated with this is highly appreciated. Thank you
RickeyFight
Snapping is possible but I have not seen anything like what you have described.
You might be able to start with this:
Default editing widget | ArcGIS API for JavaScript 3.17Y
