Any suggestion on edit features participated in geometric network?
1030
09-20-2024 03:47 AM
baohuachu2
Have about 2000 points and lines features to be added in geometric network.  Is it possible to use Javascript SDK feature service's applyEdits to do it? I tested on the rest service page to use applyEdit method, the time is more than default arcgis server's max time(10minutes).
mleahy_cl
Does it work if you do it in smaller batches?  I've had to do that in some situations where the complexity of the data (e.g., very large/detailed polygons) would occasionally cause applyEdits on a regular feature service to timeout.  The simplest solution in my case was to reduce the number of records that are added/updated in each request.
mleahy_cl
baohuachu2
By reducing the number of features of each request, increase the gis server instances, it works. On my server each request put 500 features, the time is about  3 minutes .
