Angular events disagrees w/ ES Modules graphics
1351
04-20-2021 05:06 AM
JohnWyant
Good morning,
I've been in touch w/ support on this issue and they have confirmed that it exists but angular is out of there scope. So really hoping for some dev help (or very knowledgeable user help!).
I have a couple cases. The first is that I need to draw a polygon INSIDE a http response. The polygon creation seems to work but it doesn't show up on the map until you zoom in/out. It looks like some sort of event race condition would be my guess.
The other case is very similar, I have a graphic that gets redrawn on regular intervals from input of a websocket. Normally this works, but if I add rotation to the graphic, it suffers the same issue where you have to zoom in/out in order for it to show up temporarily (before it is moved again).
I've attached a zip file of the polygon case.
Thanks in advance for any help!
AndyGup
@JohnWyant which API modules are you using, e.g. arcgis-js-api or @arcgis/core? Try testing with our "next" build: https://github.com/Esri/feedback-js-api-next. We fixed a bug at 4.19 that sounds similar. 4.19 will be in production later this week or next week.
JohnWyant
@AndyGup @arcgis/core is what I was using for 4.18.
I just tested @next/v4.19 and it does resolve both of the issues.
Thanks!
