Angular 19 - Portal Authentication Sample
1328
11-26-2024 07:03 AM
PierreMasson
import { Component, Inject, OnInit, CUSTOM_ELEMENTS_SCHEMA } from '@angular/core';
import { CommonModule, DOCUMENT } from '@angular/common';
import IdentityManager from "@arcgis/core/identity/IdentityManager";
import ServerInfo from "@arcgis/core/identity/ServerInfo";
@Component({
  selector: 'app-home',
  standalone: true,
  imports: [ CommonModule ],
  providers: [ ],
  templateUrl: './home.component.html',
  styleUrl: './home.component.scss',
  schemas: [CUSTOM_ELEMENTS_SCHEMA]
export class HomeComponent implements OnInit {
  constructor() { }
  ngOnInit(): void {
    var si = new ServerInfo({
      hasPortal: true,
      server: 'http://myportal.mydomain.com/arcgis',
    IdentityManager.registerServers([si]);
    IdentityManager.getCredential(environment.portalUrl);
    IdentityManager.checkSignInStatus(si.server + "/sharing")
    .then(() => {
      console.log("checkSignInStatus: User is signed in.");
    .catch(() => {
      console.error("checkSignInStatus: User not signed in.")
I'm developping an Angular 19 app using @ArcGIS/core && @ArcGIS/map-components and thing are going well. Only thing left to do is the portal authentication (get a token).
Is there a sample somewhere to help me. I find stuff here and there some with deprecated stuff, some in pure JS but I want to do it cleanly with Angular.
I have tried this but I get this erreor after the build:
Error when evaluating SSR module.. ReferenceError: ResizeObserver is not defined
Can you help with a sample please?
@Component({
  standalone: true,
  providers: [ ],
  constructor() { }
  ngOnInit(): void {
      hasPortal: true,
    .then(() => {
    .catch(() => {
PierreMasson
I disabled ssr in my angular.json file and it seems to work.
 "prerender": false,
 "ssr": false
