<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <title>Maps Toolbar</title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script></script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/"></script> <script> define([ "dojo/ready", "esri/map", "esri/toolbars/Draw", "esri/graphic", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "dojo/_base/Color", "dojo/_base/connect", "dijit/layout/ContentPane", "dijit/layout/BorderContainer", "dijit/form/Button", "dojo/parser" ],function(ready, Map, Draw, Graphic, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, Color, connect){ ready(function () { var map, toolbar, symbol, geomTask; function init() { map = new Map("map", { basemap: "streets", center: [-15.469, 36.428], zoom: 3 }); connect.connect(map, "onLoad", createToolbar); } function createToolbar(themap) { toolbar = new Draw(map); connect.connect(toolbar, "onDrawEnd", addToMap); } function addToMap(geometry) { toolbar.deactivate(); map.showZoomSlider(); switch (geometry.type) { case "point": var symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 10, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255,0,0]), 1), new Color([0,255,0,0.25])); break; case "polyline": var symbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASH, new Color([255,0,0]), 1); break; case "polygon": var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT, new Color([255,0,0]), 2), new Color([255,255,0,0.25])); break; case "extent": var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT, new Color([255,0,0]), 2), new Color([255,255,0,0.25])); break; case "multipoint": var symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 20, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0,0,0]), 1), new Color([255,255,0,0.5])); break; } var graphic = new Graphic(geometry, symbol); map.graphics.add(graphic); } init(); }) }); </script> </head> <body class="claro"> <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;"> <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="height:75px;text-align:left;font-weight:bold;font-size:14px;color:#400D12;overflow:hidden;"> <span>Draw:<br /></span> <button data-dojo-type="dijit/form/Button" data-dojo-props="onClick:function(){toolbar.activate(esri.toolbars.Draw.POINT);map.hideZoomSlider();}">Point</button> <button data-dojo-type="dijit/form/Button" data-dojo-props="onClick:function(){toolbar.activate(esri.toolbars.Draw.MULTI_POINT);map.hideZoomSlider();}">Multipoint</button> <button data-dojo-type="dijit/form/Button" data-dojo-props="onClick:function(){toolbar.activate(esri.toolbars.Draw.LINE);map.hideZoomSlider();}">Line</button> <button data-dojo-type="dijit/form/Button" data-dojo-props="onClick:function(){toolbar.activate(esri.toolbars.Draw.POLYLINE);map.hideZoomSlider();}">Polyline</button> <button data-dojo-type="dijit/form/Button" data-dojo-props="onClick:function(){toolbar.activate(esri.toolbars.Draw.POLYGON);map.hideZoomSlider();}">Polygon</button> <button data-dojo-type="dijit/form/Button" data-dojo-props="onClick:function(){toolbar.activate(esri.toolbars.Draw.FREEHAND_POLYLINE);map.hideZoomSlider();}">Freehand Polyline</button> <button data-dojo-type="dijit/form/Button" data-dojo-props="onClick:function(){toolbar.activate(esri.toolbars.Draw.FREEHAND_POLYGON);map.hideZoomSlider();}">Freehand Polygon</button> <!--The Arrow,Triangle,Circle and Ellipse types all draw with the polygon symbol--> <button data-dojo-type="dijit/form/Button" data-dojo-props="onClick:function(){toolbar.activate(esri.toolbars.Draw.ARROW);map.hideZoomSlider();}">Arrow</button> <button data-dojo-type="dijit/form/Button" data-dojo-props="onClick:function(){toolbar.activate(esri.toolbars.Draw.TRIANGLE);map.hideZoomSlider();}">Triangle</button> <button data-dojo-type="dijit/form/Button" data-dojo-props="onClick:function(){toolbar.activate(esri.toolbars.Draw.CIRCLE);map.hideZoomSlider();}">Circle</button> <button data-dojo-type="dijit/form/Button" data-dojo-props="onClick:function(){toolbar.activate(esri.toolbars.Draw.ELLIPSE);map.hideZoomSlider();}">Ellipse</button> </div> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"> </div> </div> </body> </html>
Solved! Go to Solution.
Additional question to Class Draw:
If I would like to change the text in the Draw toolbar, I am using the esri.bundle as explained in the documentation: http://developers.arcgis.com/en/javascript/jsapi/draw-amd.html
Ex: esri.bundle.toolbars.draw.addPoint = "Add a new tree to the map";
Using AMD it fails referencing esri.bundle. Is there any AMD compliant for esri.bundle?
require( [ "dojo/ready", "dojo/on", "dojo/dom", "dojo/_base/connect", "esri/map","esri/toolbars/draw", "esri/graphic", "esri/symbols/SimpleMarkerSymbol" ], function(ready, on, dom, connect, Map, Draw, Graphic, SimpleMarkerSymbol) { ready(function(){ on(dom.byId("pointTool"), "click", function(e){ window.toolbar.activate(Draw.POINT); }); window.map = new Map("map",{ basemap:"oceans", center:[-102,40], //long, lat zoom:5 }); window.map.on("load", function(){ window.toolbar = new Draw(window.map); connect.connect(window.toolbar,"onDrawEnd", addToMap); }); }); function addToMap(geometry){ //add the graphic to the map var symbol = new SimpleMarkerSymbol(); var graphic = new Graphic(geometry, symbol); window.map.graphics.add(graphic); } } );
