"copyright" property of layers
1609
05-12-2010 07:37 AM
LisaHallberg
I am trying to access the "copyright" property of ESRI's ArcGISTiledMapServiceLayer (http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer) and I can't seem to see it.
Can someone confirm for me that this property is working in v1.6 of the API?
Thanks.
DerekSwingley
OK, thanks for the additional info. If that's what you're looking for, then you specify service.copyright, not copyrightText. This works for me:
dojo.connect(map, "onLoad", function() {dojo.byId('copyright').innerHTML = service.copyright; } );
DerekSwingley
You mean copyrightText? This is with 2.0 but it should work with 1.6 too:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <title> Topographic Map</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.0/js/dojo/dijit/themes/tundra/tundra.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
    </style>
    <script type="text/javascript">var djConfig = {parseOnLoad: true};</script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.0"></script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      function init() {
        esri.request({
          'url': 'http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer',
          'content': { 'f': 'json' },
          'callbackParamName': 'callback',
          'load': function(data) {
            dojo.byId('copyright').innerHTML = data.copyrightText;
          'error': function(error) { console.log(error); }
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="tundra">
    <div id="copyright">
      getting copyright info...
    </div>
  </body>
</html>
LisaHallberg
I'm looking at this documentation:
http://resources.esri.com/help/9.3/arcgisserver/apis/javascript/arcgis/help/jsapi_start.htm#jsapi/ar...
For the Tiled and Dynamic layer types, it suggests that I should be able to refer to the "copyright" property of the service.
However, if I do the following, neither the "copyright" nor "copyrightText" properties are defined. The code example you sent before worked fine.
<html>
  <head>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/1.6/js/dojo/dijit/themes/tundra/tundra.css">
    <style>
    </style>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.6"></script>
   var map, service;
      function init() {
    service = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer", { opacity: 1 } );
  map = new esri.Map("map", { nav: true, displayGraphicsOnPan: false,
   extent: new esri.geometry.Extent( {xmin:-102.42486076944752, xmax:-94.2168412305526, ymin:35.75871499385985, ymax:41.23753400614044, spatialReference:new esri.SpatialReference( {wkid:4326} ) } ) } );
  map.addLayer(service);
  dojo.connect(map, "onLoad", function() {dojo.byId('copyright').innerHTML = service.copyrightText; } );
    </script>
  </head>
   <div id="map"></div>
    </div>
  </body>
</html>
DerekSwingley
