AMD Dojo Object not returning what it SHOULD be
4468
07-16-2015 09:26 AM
SteveCole
Honored Contributor
So I'm neck deep in migrating a legacy app to AMD style and I've run into this once or twice but here's the most recent example. In my legacy app, this was a seperate JS file which simply opens a Dojo dialog containing some help/instructional content about the app and had a button to open a PDF help document. Nothing earth shattering here. I've converted it to an AMD module and it (seems) to load fine:
define ([
    "dojo/_base/array",
    "dojo/_base/connect",
    "dojo/_base/declare",
    "dojo/_base/sniff",
    "dojo/has",
    "dojox/widget/Dialog",
    "dijit/form/Button",
    "dijit/place",
    "dojo/domReady!"
], function (
    array, connect, declare, has, Dialog, Button, place
    return declare(null,{
        showHelp: function() {
            var htmlFragment = '<some html formatted content>';
            // Create the help dialog
            var dialogBox = new Dialog({
                title: "About my app",
                content: htmlFragment,
                style: "width:960px;height:585px;background:#FFFFD4",
                autofocus: !has("ie"), // NOTE: turning focus ON in IE causes errors when reopening the dialog
                refocus: !has("ie")
            var btn = new Button({ label: "Close Help", style: "float:right;padding:10px 25px 10px 0px;font-weight:bold" });
            dialogBox.containerNode.appendChild(btn.domNode);
            connect.connect(btn, "onClick", function(){
                dialogBox.destroy();
            var btn2 = new Button({ label: "Open PDF User Guide", style: "float:left;padding:10px 0px 10px 25px;font-weight:bold" });
            dialogBox.containerNode.appendChild(btn2.domNode);
            connect.connect(btn2, "onClick", function(){
                window.open("http://some.pdf", 'resizable,scrollbars');
            // Display the dialog
            dialogBox.show();
When I click the button on my HTML page that fires off showHelp, I get "Uncaught TypeError: Cannot read property 'appendChild' of undefined."
When I pause my code to examine the dialog object, it CLEARLY does not match what the API specifies it should:
I've tried "dijit/Dialog" and "dojox/widget/Dialog" but it's always the same result. The dojo version loaded is 1.10.x (I'm referencing ESRI's CDN URL for the JS API and dojo, BTW). The easy, short term answer is to just continue to use dijit.Dialog but I want to know WHY I'm not seeing the proper dijit/Dialog that I should be seeing.
Any ideas?
Steve
TimWitt2
Steve,
I think you are missing sniff in your function, which throws off the order.
  1. define ([
  2.     "dojo/_base/array"
  3.     "dojo/_base/connect"
  4.     "dojo/_base/declare"
  5.     "dojo/_base/sniff"
  6.     "dojo/has"
  7.     "dojox/widget/Dialog"
  8.     "dijit/form/Button"
  9.     "dijit/place"
  10.     "dojo/domReady!"
  11. ], function
  12.     array, connect, declare, sniff, has, Dialog, Button, place
  13. ) {
TimWitt2
Steve,
  1. define ([
  6.     "dojo/has"
  9.     "dijit/place"
  11. ], function
  13. ) {
SteveCole
Honored Contributor
sonofa-
Thanks, Tim. Pretty embarrassing that I missed that, given the short list of requires. Doh!
Ken Buja​ Thanks for the note about connect. I did not know that. I'm still using it elsewhere in my converted app so I'll go back in and swap those over to On.
Thanks guys!
TimWitt2
Steve,
It happens to all of us
Tim
KenBuja
MVP Esteemed Contributor
In addition to Tim's correct answer, you should get away from using dojo/_base/connect. This has been deprecated, so you should use dojo/on for event handling.
