Allow user to add their own image to a print layout template?
3429
04-19-2016 04:03 PM
MaxMcCosham
Hello,
Is it possible to create a custom print layout template that will allow the user of a web application to add their own image to the print?
khairulamri
Hi Max,
For custom printing tools, you can refer to this url : Tutorial: Publishing additional services for printing—Documentation | ArcGIS for Server
here is the step to add your image/logo to print layout template
1. prepare your layout template.
2. click Insert menu > Picture.
3. once the image has added on your layout, right click on that image, select properties.
4. check option save image as Part of Document
5. run export web map tools
6. publish gp result as gp services
7. do the print using your new gp print service
Regards,
Amri
khairulamri
Hi Max,
Regards,
Amri
PrasadG
it solve  my problem...
