Allow json MIME type for Javascript Web Applications - Security Risks
1503
10-24-2013 10:13 AM
MichaelVolz
Esteemed Contributor
To All Javascript Developers and Web Server Administrators:
I recently downloaded an ESRI javascript web application template to a web server.  I tried to run the application using ArcGIS Online services, but it stalled on the splash page with a 404 error in Fiddler.  With a little research and past experience, I determined that it was the json MIME type not being allowed through IIS that was throwing the 404 error.  I added this MIME type and the javascript web application now works.
I am wondering if I am introducing any security risks to my server by allowing this additional MIME type as it is not in the MIME type list by default?
If there is a security risk, what other configuration changes do I need to make to the server to close this security risk?
Any help or information in regard to this post are greatly appreciated.
JeffPace
Is your IIS directly exposed to the internet/ in a DMZ? if so then yes, there are some json hijacking concerns
http://security.stackexchange.com/questions/7001/how-should-web-app-developers-defend-against-json-h...
I for one (besides the obvious dont use IIS) would recommend installing your application behind a Web Application Firewall and making sure you are doing request filtering to guard against attacks and exploits
We use mod-proxy
http://httpd.apache.org/docs/2.2/mod/mod_proxy.html
and keep our tomcat server internal allowing things only as necessary.
