AGSJS
7137
8
10-07-2013 05:45 AM
MatejSkerjanc
Hello
we're using http://gmaps-utility-gis.googlecode.com/svn-history/r354/trunk/agsjs/docs/toc/examples.html
AGSJS Table of content
It seems it's using the dojo tree.
Dojo tree has collapse methods, while icannot find collapse method for this tree.
I need to collapse certain nodes, but i find no function available to achieve this. If anyone's more experienced in this it would help me tons.
Regards
Matej
KenBuja
It turns out that this capability exists in the current TOC version. You can use
toc.findTOCNode(layerDynamic, 1).hide(); to remove layer 1
and
toc.findTOCNode(layerDynamic, 1).show(); to make it visible again.
See this sample. It will affect the Fire Stations legend entry.
If you want to do this when the TOC is being created, you'll have to put it into the Load event
            map.on("layers-add-result", function (evt) {                 toc = new TOC({                     map: map,                     layerInfos: [{                         layer: layerDynamic,                         title: "Legend",                         slider: true                     }]                 }, 'legendDiv');                 toc.startup();                                toc.on("load", function () {                     toc.findTOCNode(layerDynamic, 1).hide();                 });                            });
KenBuja
There is a new version of the TOC tool that has the ability to collapse nodes. This is the latest version.
MatejSkerjanc
Thanks! This will do.
MatejSkerjanc
Another question regarding AGSJS, is it possible to omit certain feature layer by ID? I just want it out of the TOC but otherwise visible on the map.
Regards,
Matej
MatejSkerjanc
it seems
var lyr = toc.findTOCNode(map.getLayer("operational0"), id);
                if (id == 5)
                    lyr.destroy();
works but its "buggy". It causes TOC to cease working correctly. Actually it works per se but reports bunch of errors on layer toggling.
JeffPace
MVP Alum
instead of destroying,. maybe try
domStyle.set(lyr, 'visibility', 'hidden');
or
domStyle.set(lyr, 'display', 'none');
KenBuja
Unfortunately, neither of those work. I can see the visible attribute within lyr.data, but how do I set that to false?
[ATTACH=CONFIG]29504[/ATTACH]
KenBuja
and
MatejSkerjanc
oh haha seriously? hide?
Thanks sirs, i used display none on the dom already but seemed so ... you know not clean.
I definitely prefer the hide method when provided.
Is it just me or am i blind, but....documentation seems a bit shoddy. But very nice tool.
Thank you both for the help!
