After search Dojo data Grid won't show the result and weird behavior
1312
06-27-2013 11:00 AM
by Anonymous User
Not applicable
Original User: dexconor
So, this is my search
[ATTACH=CONFIG]25556[/ATTACH]
I type 5 into search box and the results are highlighted but no result shows
[ATTACH=CONFIG]25557[/ATTACH]
Below is the weird thing, if I change size of browser then it shows top of rows other wise
remains above
[ATTACH=CONFIG]25558[/ATTACH]
        findTask = new esri.tasks.FindTask("http://localhost:6080/arcgis/rest/services/fc/agr/MapServer");
        dojo.connect(map, "onLoad", function() {
          //Create the find parameters
          findParams = new esri.tasks.FindParameters();
          findParams.returnGeometry = true;
          findParams.layerIds = [2];
          findParams.searchFields = ["OBJECTID","Number","Abbrev","CampusCode"];
          findParams.outSpatialReference = map.spatialReference;
          console.log("find sr: ", findParams.outSpatialReference);
function doFind() {
     findParams.searchText = dojo.byId("searchField").value;
        findTask.execute(findParams,showResults);
      function showResults(results) {
        map.graphics.clear();
        var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([98,194,204]), 2), new dojo.Color([98,194,204,0.5]));
        var items = dojo.map(results,function(result){
          var graphic = result.feature;
          graphic.setSymbol(symbol);
          map.graphics.add(graphic);
          return result.feature.attributes;
        var data = {
          identifier: "OBJECTID",
          label: "OBJECTID",
          items: items
        store = new dojo.data.ItemFileReadStore({ data:data });
  var grid = registry.byId('grid');
  grid.setStore(store);
        map.centerAndZoom(center, zoom);
      function onRowClickHandler(evt){
        var clickedTaxLotId = grid.getItem(evt.rowIndex).OBJECTID;
        var selectedTaxLot;
        dojo.forEach(map.graphics.graphics,function(graphic){
          if((graphic.attributes) && graphic.attributes.OBJECTID === clickedTaxLotId){
            selectedTaxLot = graphic;
            return;
        var taxLotExtent = selectedTaxLot.geometry.getExtent();
        map.setExtent(taxLotExtent);
<div class ="toggle" id="menu_subA">Enter building number, name and abbreviation<br>
  <input type="text" id="searchField" size="30" value="" /><button data-dojo-type="dijit.form.Button"  onClick="doFind();" value="Search">
        Search
      </button>
<table data-dojo-type="dojox.grid.DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'10px'">
      <thead>
        <tr>
          <th field="Number" width="50">Num</th>
          <th field="Abbrev" width="50">Abbr</th>
          <th field="CampusCode" width="50">Camp</th>
        </tr>
      </thead>
    </table>
  </div>
I presume it's because of div that surrounded data grid?
and the div is a slide menu using jquery.
is there any way that I can fix both?
BenFousek
Try resizing your grid after setting the store
grid.resize();
Also check out the api reference http://dojotoolkit.org/api/ for dojox/grid/DataGrid and look at the sizing/display properties like autoHeight and autoWidth. Grids are inexplicably temperamental. Depending on the type of container it's in or how it's created (programmatic or declarative) make a difference in rendering.
Also, try wrapping the grid in a plain dijit/layout/ContentPane with no padding. I'm not sure if jquery is causing problems, but this should help if it is.
by Anonymous User
Not applicable
grid.resize();
Thanks Ben, but unfortunately didn't work about I'll check that reference
I've tried
  grid.set("store",store);
  dijit.byId(grid).resize();
  grid.placeAt("grid");
  grid.startup();
  grid.resize();
all these but nothing happened.
