After Adding Second Apply Edits Layers Neither Update
3195
06-08-2015 12:16 PM
ChrisSergent
I have uploaded my recent version of my application on github: csergent45/streetSigns at 8b5b613676474eebed160981cb654b41107da459 · GitHub  I also republished the application at Street Signs  - If you try it, don't allow location as it will not show you the map because the data is for Decatur, Illinois.
Before I had an issue with my updates not being applied because I was not converting an ObjectId to a number, but I do that with both forms and neither will now update. Any ideas what I am doing wrong? :
The sign layer information on click:
var installed, signId, facing, visibility, condition, supportId, text, color1, delineator, illum, offset;
            var mountht, backing, width, height, txtSize, numSize, comments, twoSided, attachType, attachNum, attachLoc, siteObs, signShape, color2, mutcd;
            var objectId;
            objectId = evt.graphic.attributes.OBJECTID;
            mutcd = evt.graphic.attributes.MUTCD;
            installed = evt.graphic.attributes.INSTALLED;
            signId = evt.graphic.attributes.SIGNID;
            facing = evt.graphic.attributes.FACING;
            visibility = evt.graphic.attributes.VISIBILITY;
            condition = evt.graphic.attributes.CONDITION_;
            supportId = evt.graphic.attributes.SUPPORTID;
            text = evt.graphic.attributes.TEXT;
            color1 = evt.graphic.attributes.COLOR1;
            delineator = evt.graphic.attributes.DELINEATOR;
            illum = evt.graphic.attributes.ILLUM;
            offset = evt.graphic.attributes.OFFSET;
            mountht = evt.graphic.attributes.MOUNTHT;
            backing = evt.graphic.attributes.BACKING;
            width = evt.graphic.attributes.WIDTH;
            height = evt.graphic.attributes.HEIGHT;
            txtSize = evt.graphic.attributes.TXTSIZE;
            numSize = evt.graphic.attributes.NUMSIZE;
            comments = evt.graphic.attributes.COMMENTS;
            twoSided = evt.graphic.attributes.TWOSIDED;
            attachType = evt.graphic.attributes.ATTACHTYPE;
            attachNum = evt.graphic.attributes.ATTACHNUM;
            attachLoc = evt.graphic.attributes.ATTACHLOC;
            siteObs = evt.graphic.attributes.SITEOBS;
            signShape = evt.graphic.attributes.SIGNSHAPE;
            color2 = evt.graphic.attributes.COLOR2;
            // Clear form of values before connecting current values
            document.getElementById("signForm").reset();
            /* Enter your domain item and then the element to populate */
            populateSelect("MUTCD", "mutcd", "sign");
            populateSelect("VISIBILITY", "visibility", "sign");
            populateSelect("CONDITION_", "condition", "sign");
            populateSelect("COLOR1", "color1", "sign");
            populateSelect("DELINEATOR", "delineator", "sign");
            populateSelect("ILLUM", "illum", "sign");
            populateSelect("BACKING", "backing", "sign");
            populateSelect("ATTACHTYPE", "attachType", "sign");
            populateSelect("ATTACHLOC", "attachLoc", "sign");
            populateSelect("SITEOBS", "siteObs", "sign");
            populateSelect("SIGNSHAPE", "signShape", "sign");
            populateSelect("COLOR2", "color2", "sign");
            /* Populate form with data */
            document.getElementById("signObjectId").value = objectId;
            document.getElementById("mutcd").value = mutcd;
            document.getElementById("installed").value = installed;
            document.getElementById("signId").value = signId;
            document.getElementById("facing").value = facing;
            document.getElementById("visibility").value = visibility;
            document.getElementById("condition").value = condition;
            document.getElementById("supportId").value = supportId;
            document.getElementById("text").value = text;
            document.getElementById("color1").value = color1;
            document.getElementById("delineator").value = delineator;
            document.getElementById("illum").value = illum;
            document.getElementById("offset").value = offset;
            document.getElementById("mountht").value = mountht;
            document.getElementById("backing").value = backing;
            document.getElementById("width").value = width;
            document.getElementById("height").value = height;
            document.getElementById("txtSize").value = txtSize;
            document.getElementById("numSize").value = numSize;
            document.getElementById("comments").value = comments;
            document.getElementById("twoSided").value = twoSided;
            document.getElementById("attachType").value = attachType;
            document.getElementById("attachNum").value = attachNum;
            document.getElementById("attachLoc").value = attachLoc;
            document.getElementById("siteObs").value = siteObs;
            document.getElementById("signShape").value = signShape;
            document.getElementById("color2").value = color2;
            document.getElementById("btnSignUpdate").style.visibility = "visible";
            // Show signs form for updating
            app.attributesSignModal.modal("show");
        /* Update Sign Layer End */
The sign layer update:
 // get sign attributes from form and submit
    var updateSigns = function () {
        // alert(domClass.contains("attributesSignModal", "in"));
        var attributes = {
            // TODO: not sure if this is needed
            //requestreceived: null
        var currentDate = new Date(); // current date is defined but never used.
        var graphic;
        graphic = new Graphic(app.currentGeometry);
        query("#attributesSignModal input, #attributesSignModal select, #attributesSignModal textarea").forEach(function (formInput) {
            attributes[formInput.name] = formInput.value;
        // Form validation - ensures that the values for the data are here if left blank
        if ((attributes.installed === undefined) || (attributes.installed === "")) {
            attributes.installed = null;
        if ((attributes.signId === undefined) || (attributes.signId === "")) {
            attributes.signId = null;
        if ((attributes.supportId === undefined) || (attributes.supportId === "")) {
            attributes.supportId = null;
        attributes.signObjectId = parseInt(attributes.signObjectId, 10);
        graphic.setAttributes(attributes);
        stopCaptureRequest();
        console.log(attributes);
        app.signLayer.applyEdits(null, [graphic], null).then(function (response) {
            console.log(response);
        app.signLayer.refresh();
And here is the information for the support layer that was working before:
Support layer onClick:
 /* Update Support Layer Begin */
        app.supportLayer.on("click", function (evt) {
            /* Get support information on click */
            var objectId, supportId, type, address, size, material, base, rating, dateInv, inspector, comments, addrCode;
            // declare rest endpoint values
            type = evt.graphic.attributes.TYPE;
            address = evt.graphic.attributes.ADDRESS;
            size = evt.graphic.attributes.SIZE_;
            material = evt.graphic.attributes.MATERIAL;
            base = evt.graphic.attributes.BASE;
            rating = evt.graphic.attributes.RATING;
            dateInv = evt.graphic.attributes.DATEINV;
            inspector = evt.graphic.attributes.INSPECTOR;
            addrCode = evt.graphic.attributes.ADDRCODE;
            document.getElementById("supportForm").reset();
            populateSelect("TYPE", "type", "support");
            populateSelect("SIZE_", "size", "support");
            populateSelect("MATERIAL", "material", "support");
            populateSelect("BASE", "base", "support");
            populateSelect("RATING", "rating", "support");
            document.getElementById("objectId").value = objectId;
            document.getElementById("address").value = address;
            document.getElementById("type").value = type;
            document.getElementById("size").value = size;
            document.getElementById("material").value = material;
            document.getElementById("base").value = base;
            document.getElementById("rating").value = rating;
            document.getElementById("dateInv").value = dateInv;
            document.getElementById("inspector").value = inspector;
            document.getElementById("addrCode").value = addrCode;
            // Show supports form for updating
            document.getElementById("btnSupportUpdate").style.visibility = "visible";
            app.attributesModal.modal("show");
        /* Update Support Layer End */
Support layer update:
// get attributes from form and submit
    var updateSupports = function () {
        //alert(domClass.contains("attributesModal", "in"));
        var attributes = {
        var graphic;
        query("#attributesModal input, #attributesModal select, #attributesModal textarea").forEach(function (formInput) {
        // Form Validation - ensures that the values for the database are here if left blank
        if ((attributes.dateInv === undefined) || (attributes.dateInv === "")) {
            attributes.dateInv = null;
        if ((attributes.addrCode === undefined) || (attributes.addrCode === "")) {
            attributes.addrCode = null;
        attributes.objectId = parseInt(attributes.objectId, 10);
        //console.log(attributes);
        app.supportLayer.applyEdits(null, [graphic], null).then(function (response) {
        app.supportLayer.refresh();
ChrisSergent
I would like to thank Kyle Morgan​ for helping me out with this issue. It has been resolved and here is the solution, should you need it. If you create two forms, you need to watch out for duplicate form element names. Both layers have an OjectId but on one form I used signObjectId, but this will not permit your updated code to go to the server, you need to convert your field signObjectId to objectId. You also want to refresh the graphics to ensure that the data displays the updated data on the next click event as follows:
// Preparing the data for processing to the server
        attributes.ObjectID = parseInt(attributes.signObjectId, 10);
        delete attributes.signObjectId;
        attributes.supportId = parseInt(attributes.signSupportId, 10);
        delete attributes.signSupportId;
        attributes.comments = attributes.signComments;
        delete attributes.signComments;
        // refreshing the layer and graphics to update the points for the onclick method
        graphic.refresh();
