Adding WCS and WFS layers using arc GIS java script API?
1054
11-28-2013 10:07 PM
Pankajroy
Hi All,
Is it possible to add WMS, WCS and WFS layers using ArcGIS java script API.
For WCS and WFS layers I did not find any sample. Possible to add them using Open layers?
Tried to add WFS as a feature layer and WCS as image layer but to no use.
WMS layers can be added using WMSLAYER but in my case I don't see the layer added to the map, it is not throwing any error but at the same time not adding the layer as well...
Thanx In Advance,
Pankaj Roy
Pankajroy
After adding WMS layer when i check the URL response in fiddler i get the following error
<?xml version="1.0" encoding="UTF-8" standalone="true"?>
-<ServiceExceptionReport version="1.3.0" xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.opengis.net/ogc"><ServiceException code="InvalidSRS(CRS)"> Parameter 'srs(crs)'
can not be empty. </ServiceException></ServiceExceptionReport>
Following is the code i have written
function handleWMSLayer() {
    var layer1 = new esri.layers.WMSLayerInfo({ name: "1", title: "DC_SECTOR" });
    var resourceInfo = {
        extent: map.extent,
        layerInfos: [layer1]
   var wmsLayer = new esri.layers.WMSLayer("http://localhost:6080/arcgis/services/SIGMA/SIGMA_WMS/MapServer/WMSServer",
            resourceInfo: resourceInfo,
            visibleLayers:['1']
    wmsLayer.setImageFormat("png");
    map.addLayer(wmsLayer);
Thanx,
Pankaj Roy
