adding and editing tooltips for the layerList legend
5876
8
03-20-2019 10:39 AM
JayHill
I'm trying to add and change the default tooltips in the layerList legend widget of the 4.10 api. I have had no luck trying
document.getElementsByClassName('esri-layer-list__item-toggle').title or innerHMTL = "<span>tooltip</span>"
RobertScheitlin__GISP
Jay,
   Here is what works in your workflow:
      //Panel widgets - layerlist
      var layerList = new LayerList({
        view: app.activeView,
        container: "legendDiv",
        listItemCreatedFunction: function(event) {
          const item = event.item;
          setTimeout(function() {
            var eyeArr = query('.esri-layer-list__item-toggle');
            if(eyeArr.length){
              eyeArr.map(function(node){
                node.title = "Turn Layer On/Off";
          }, 500);
Jay,
  This works:
      // Add a legend instance to the panel of a
      // ListItem in a LayerList instance
      const layerList = new LayerList({
        view: view,
          setTimeout(function(){
            document.getElementsByClassName('esri-layer-list__item-toggle')[0].title = "blah";
          }, 500);
          if (item.layer.type != "group") { // don't show legend twice
            item.panel = {
              content: "legend",
              open: true
JayHill
Robert
I tried this but it didn't produce a tooltip. I have included the code below.
<script>
var app;
require([
    "esri/Map",
    "esri/Basemap",
    "esri/Graphic",
    "esri/layers/FeatureLayer",
    "esri/layers/GroupLayer",
    "esri/views/MapView",
    "esri/views/SceneView",
    "esri/support/ContentElement/Attachments",
    "esri/widgets/Search",
    "esri/core/watchUtils",
    "esri/widgets/Home",
    "esri/widgets/Zoom",
    "esri/widgets/Compass",
    "esri/widgets/Locate",
    "esri/widgets/Legend",
    "esri/widgets/BasemapToggle",
    "esri/widgets/LayerList",
    "esri/tasks/QueryTask",
    "esri/tasks/support/Query",
    "dojo/query",
    "dojo/_base/declare",
    "dojo/request",
    // Calcite-maps
    "calcite-maps/calcitemaps-v0.10",
    "calcite-maps/calcitemaps-arcgis-support-v0.10",
    // Bootstrap
    "bootstrap/Collapse",
    "bootstrap/Dropdown",
    "bootstrap/Tab",
    "dojo/on",
    "dojo/dom",
    "dojo/dom-construct",
    "dojo/domReady!"
], function(Map, Basemap, Graphic, FeatureLayer, GroupLayer, MapView, SceneView, AttachmentsContentElement, Search, watchUtils, Home, Zoom, Compass, Locate, Legend, BasemapToggle, LayerList, QueryTask, Query, query, declare, request, CalciteMaps, CalciteMapsArcGIS, on, dom) {
    // App
    app = {
        zoom: 8,
        center: [-112, 39.5],
        basemap: "topo",
        viewPadding: {
            top: 50,
            bottom: 0
        uiPadding: {
            top: 15,
            bottom: 15
        map: null,
        mapView: null,
        sceneView: null,
        activeView: null,
        searchWidgetNav: null,
        containerMap: "mapViewDiv",
        containerScene: "sceneViewDiv"
    // Map
    app.map = new Map({
        basemap: app.basemap,
        //ground: "world-elevation"
    // 2D View
    app.mapView = new MapView({
        container: app.containerMap, // deactivate
        map: app.map,
        zoom: 8,
        padding: app.viewPadding,
        ui: {
            components: ["zoom", "compass", "home"],
            padding: app.uiPadding
    // 3D View
    app.sceneView = new SceneView({
        container: null, // activate
        map: app.map,
        zoom: app.zoom,
        center: app.center,
        ui: {
    // Active view is scene
    setActiveView(app.mapView);
    // Create search widget
    app.searchWidgetNav = new Search({
        container: "searchNavDiv",
        includeDefaultSources: false,
    // Wire-up expand events
    CalciteMapsArcGIS.setSearchExpandEvents(app.searchWidgetNav);
    CalciteMapsArcGIS.setPopupPanelSync(app.mapView);
    CalciteMapsArcGIS.setPopupPanelSync(app.sceneView);
    // Menu UI - change Basemaps
    query("#selectBasemapPanel").on("change", function(e) {
        app.mapView.map.basemap = e.target.options[e.target.selectedIndex].dataset.vector;
        app.sceneView.map.basemap = e.target.value;
    // Tab UI - switch views
    query(".calcite-navbar li a[data-toggle='tab']").on("click", function(e) {
        if (e.target.text.indexOf("2D") > -1) {
            syncViews(app.sceneView, app.mapView);
        } else {
            syncViews(app.mapView, app.sceneView);
            setActiveView(app.sceneView);
        syncSearch(app.activeView);
    // Views
    function syncViews(fromView, toView) {
        var viewPt = fromView.viewpoint.clone();
        fromView.container = null;
        if (fromView.type === "3d") {
            toView.container = app.containerMap;
        } else {
            toView.container = app.containerScene;
        toView.viewpoint = viewPt;
        toView.padding = app.viewPadding;
    // Search Widget
    function syncSearch(view) {
        app.searchWidgetNav.view = view;
        if (app.searchWidgetNav.selectedResult) {
            watchUtils.whenTrueOnce(view, "ready", function() {
                app.searchWidgetNav.autoSelect = false;
                app.searchWidgetNav.search(app.searchWidgetNav.selectedResult.name);
                app.searchWidgetNav.autoSelect = true;
    // Active view
    function setActiveView(view) {
        app.activeView = view;
    var home = new Home({
    app.activeView.ui.add(home, "top-left");
    var locate = new Locate({
    app.activeView.ui.add(locate, "top-left");
    // Panel widgets - add legend
    var legendWidget = new Legend({
        //container: "legendDiv",
                document.getElementsByClassName('esri-layer-list__item-toggle')[0].title = "Turn Layer On/Off";
            }, 500);
                item.panel = {
                    content: "legend",
                    open: true
                if (item.layer.geometryType == "polygon") { //gets rid of the opacity tool for the point features
                    item.actionsSections = [
                            title: "Increase opacity",
                            className: "esri-icon-up",
                            title: "Decrease opacity",
                            className: "esri-icon-down",
    layerList.on("trigger-action", function(event) {
        // Capture the action id.
        var id = event.action.id;
        var title = event.item.title;
        if (title === "Mining Districts") {
            layer = miningDistricts;
        } else if (title === "Land Ownership") {
            layer = adminBounds;
        } else if (title === "Bentonite") {
            layer = bentonite;
        } else if (title === "Gypsum") {
            layer = gypsum;
        } else if (title === "Limestone") {
            layer = limestone;
        } else {
            layer = dolomite;
        if (id === "increase-opacity") {
            // if the increase-opacity action is triggered, then
            // increase the opacity of the GroupLayer by 0.1
            if (layer.opacity < 1) {
                layer.opacity += 0.1;
        } else if (id === "decrease-opacity") {
            // if the decrease-opacity action is triggered, then
            // decrease the opacity of the GroupLayer by 0.1
            if (layer.opacity > 0) {
                layer.opacity -= 0.1;
    //Popup Templates
    rockHoundingContent = function(value, key, data) {
        var content = "";
        if (key === "Material") {
            if (data.Material) {
                content += "<span class='bold' title='Name'><b>Rockhounding </b></span><b>" + data.Material + " Site</b>";
        if (key === "Material_Description") {
            if (data.Material_Description) {
                content += "<span class='bold' title='Description'><b>Material Description: </b></span>" + data.Material_Description;
        if (key === "Site_Description_Geology") {
            if (data.Site_Description_Geology) {
                content += "<br><span class='bold' title='Description'><b>Site Geology: </b></span>" + data.Site_Description_Geology;
        if (key === "Directions_To_Site") {
            if (data.Directions_To_Site) {
                content += "<br><span class='bold' title='Description'><b>Directions To Site: </b></span>" + data.Directions_To_Site;
        return content;
    geoSitesContent = function(value, key, data) {
        var content = "";
        if (key === "Picture") {
            if (data.Picture) {
                content += "<span class='bold' title='Photo'></span>" + "<a href='" + data.Picture + "' data-lightbox='photo1' target='_blank'> <img src='" + data.Picture + "' width='150' height='100'></a><br>";
        if (key === "Name") {
            content += "<span class='bold' title='Name'></span><b>" + data.Name + "</b><br>";
        if (key === "Description") {
            if (data.Description) {
                content += "<br><span class='bold' title='Description'><b>Description: </b></span>" + data.Description + "<br>";
        return content;
    miningContent = function(value, key, data) {
        var content = "";
        if (key === "District") {
            if (data.District) {
                content += "<span class='bold' title='District'></span>" + data.District + " Mining District</b><br>";
        if (key === "Commodity") {
            if (data.Commodity) {
                content += "<span class='bold' title='Commodity'><b>Commodity: </b></span>" + data.Commodity + "</b><br>";
        if (key === "Organized") {
            if (data.Organized) {
                content += "<span class='bold' title='Organized'><b>Organized: </b></span>" + data.Organized + "</b><br>";
        if (key === "Productive") {
            if (data.Productive) {
                content += "<span class='bold' title='Productive'><b>Productive: </b></span>" + data.Productive + "</b><br>";
        if (key === "Short_Tons") {
            if (data.Short_Tons) {
                content += "<span class='bold' title='Short Tons'><b>Short Tons: </b></span>" + data.Short_Tons + "</b><br>";
        if (key === "Total_Dollar_Value") {
            if (data.Total_Dollar_Value) {
                content += "<span class='bold' title='Total Dollar Value'><b>Total Dollar Value: </b></span>" + data.Total_Dollar_Value.toLocaleString('en-US', {
                    style: 'currency',
                    currency: 'USD',
                }) + "</b><br>";
        return content;
    industrialMinContent = function(value, key, data) {
        var content = "";
        if (key === "AGE") {
            if (data.AGE) {
                content += "<span class='bold' title='Age'><b>Age: </b></span>" + data.AGE + "</b><br>";
        if (key === "UNITNAME") {
            if (data.UNITNAME) {
                content += "<span class='bold' title='UNIT NAME'><b>Unit Name: </b></span>" + data.UNITNAME + "</b><br>";
            if (data.Commodity == "Gypsum") {
                content += "<br><span class='bold' title='Show complete report for " + data.Commodity + "'></span>" + "<a href='https://ugspub.nr.utah.gov/publications/blm_mineral_resources/Gypsum.pdf' target='_blank'><b>Detailed Report</b></a>";
            } else if (data.Commodity == "Dolomite") {
                content += "<br><span class='bold' title='Show complete report for " + data.Commodity + "'></span>" + "<a href='https://ugspub.nr.utah.gov/publications/blm_mineral_resources/Dolomite.pdf' target='_blank'><b>Detailed Report</b></a>";
            } else if (data.Commodity == "Limestone") {
                content += "<br><span class='bold' title='Show complete report for " + data.Commodity + "'></span>" + "<a href='https://ugspub.nr.utah.gov/publications/blm_mineral_resources/Limestone.pdf' target='_blank'><b>Detailed Report</b></a>";
        return content;
    bentMinContent = function(value, key, data) {
        var content = "";
        if (key === "Age") {
            if (data.Age) {
                content += "<span class='bold' title='Age'><b>Age: </b></span>" + data.Age + "</b><br>";
        if (key === "UnitName") {
            if (data.UnitName) {
                content += "<span class='bold' title='UNIT NAME'><b>Unit Name: </b></span>" + data.UnitName + "</b><br>";
                content += "<br><span class='bold' title='Show complete report for " + data.Commodity + "'></span>" + "<a href='https://ugspub.nr.utah.gov/publications/blm_mineral_resources/Bentonite.pdf' target='_blank'><b>Detailed Report</b></a><br>";
        return content;
    let attachmentsElement = new AttachmentsContentElement({
        displayType: "list"
    //remove panels when user clicks on map
    app.activeView.on("click", function(event) {
        app.activeView.graphics.removeAll();
        query("#panelDetails").removeClass("in");
    //renderers
    const rockHoundRenderer = {
        type: "simple", // autocasts as new SimpleRenderer()
        symbol: {
            type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
            color: [255, 71, 68],
            outline: null
    const geoSitesRenderer = {
        symbol: {
            color: [66, 194, 244],
            outline: null
    //add feature layers
    const rockHounding = new FeatureLayer({
        url: "https://maps.dnr.utah.gov/arcgis/rest/services/UGS/BLM_Rockhounding_Sites/MapServer/0",
        title: "Rockhounding Sites on BLM Land",
        outFields: ["*"],
        renderer: rockHoundRenderer,
        popupTemplate: {
            title: "<b>{Material:rockHoundingContent}</b>",
            content: "{Material_Description:rockHoundingContent}<br>{Site_Description_Geology:rockHoundingContent}<br>{Directions_To_Site:rockHoundingContent}"
        visible: false,
    const geoSites = new FeatureLayer({
        url: "https://webmaps.geology.utah.gov/arcgis/rest/services/Energy_Mineral/BLM_Mineral_Resources/MapServer/8",
        title: "GeoSights on BLM Land",
        outFields: ["*"],
        renderer: geoSitesRenderer,
        popupTemplate: {
            title: "<b>{Name:geoSitesContent}</b>",
            content: "{Picture:geoSitesContent}{Description:geoSitesContent}"
        visible: false,
    const miningDistricts = new FeatureLayer({
        url: "https://webmaps.geology.utah.gov/arcgis/rest/services/Energy_Mineral/BLM_Mineral_Resources/MapServer/6",
        title: "Mining Districts",
        outFields: ["*"],
        opacity: 0.5,
        popupTemplate: {
            title: "<b>{District:miningContent}</b>",
            content: [{
                type: "text",
                text: "{Commodity:miningContent}{Organized:miningContent}{Productive:miningContent}{Short_Tons:miningContent}{Total_Dollar_Value:miningContent}"
                type: "attachments"
        visible: true,
    const bentonite = new FeatureLayer({
        url: "https://webmaps.geology.utah.gov/arcgis/rest/services/Energy_Mineral/BLM_Mineral_Resources/MapServer/1",
        title: "Bentonite",
        opacity: 0.5,
        outFields: ["*"],
        popupTemplate: {
            title: "<b>Bentonite Potential</b>",
            content: "{Age:bentMinContent}{UnitName:bentMinContent}{Commodity:bentMinContent}"
        visible: false,
    const dolomite = new FeatureLayer({
        url: "https://webmaps.geology.utah.gov/arcgis/rest/services/Energy_Mineral/BLM_Mineral_Resources/MapServer/2",
        title: "Dolomite",
        outFields: ["*"],
        opacity: 0.5,
        popupTemplate: {
            title: "<b>Dolomite Potential</b>",
            content: "{AGE:industrialMinContent}{UNITNAME:industrialMinContent}{Commodity:industrialMinContent}"
        visible: false,
    const gypsum = new FeatureLayer({
        url: "https://webmaps.geology.utah.gov/arcgis/rest/services/Energy_Mineral/BLM_Mineral_Resources/MapServer/3",
        title: "Gypsum",
        outFields: ["*"],
        opacity: 0.5,
        popupTemplate: {
            title: "<b>Gypsum Potential</b>",
        visible: false,
    const limestone = new FeatureLayer({
        url: "https://webmaps.geology.utah.gov/arcgis/rest/services/Energy_Mineral/BLM_Mineral_Resources/MapServer/4",
        title: "Limestone",
        outFields: ["*"],
        opacity: 0.5,
        popupTemplate: {
            title: "<b>Limestone Potential</b>",
        visible: false,
    const industrialMins = new GroupLayer({
        title: "Industrial Mineral Resource Potential",
        visible: true,
        layers: [bentonite, dolomite, gypsum, limestone]
    const adminlabelClass = { // autocasts as new LabelClass()
        symbol: {
            type: "text", // autocasts as new TextSymbol()
            color: "rgba(125, 125, 125, 0.51)",
            //haloColor: "black",
            font: { // autocast as new Font()
                family: "sans-serif",
                weight: "bold"
        labelPlacement: "always-horizontal",
        labelExpressionInfo: {
            expression: "$feature.ADMIN"
    const adminBounds = new FeatureLayer({
        url: "https://webmaps.geology.utah.gov/arcgis/rest/services/Energy_Mineral/BLM_Mineral_Resources/MapServer/11",
        title: "Land Ownership",
        outFields: ["*"],
        legendEnabled: true,
        opacity: 0.15,
        visible: true,
        //labelingInfo: [adminlabelClass],
    const countylabelClass = { // autocasts as new LabelClass()
        symbol: {
                weight: "bold"
            expression: "$feature.NAME"
    const countyLayer = new FeatureLayer({
        url: "https://webmaps.geology.utah.gov/arcgis/rest/services/Energy_Mineral/BLM_Mineral_Resources/MapServer/10",
        popupEnabled: false,
        title: "Counties",
        listMode: "hide",
        opacity: 0.5,
        labelingInfo: [countylabelClass],
    const refLayers = new GroupLayer({
        title: "Reference Layers",
        visible: true,
        layers: [adminBounds, countyLayer]
    app.activeView.map.add(countyLayer);
    app.activeView.map.add(adminBounds);
    app.activeView.map.add(miningDistricts);
    app.activeView.map.add(geoSites);
    app.activeView.map.add(rockHounding);
    app.activeView.map.add(industrialMins);
  </script>
Jay,
   Can you give me the rest of the html document so I can just copy your app into a new .html file and test drive it?
JayHill
<!DOCTYPE html>
<html lang="en">
<head>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width,initial-scale=1,maximum-scale=1,user-scalable=no">
    <meta name="description" content="Utah Geologic and Mineral Resources">
    <title>Utah Geologic and Mineral Resources</title>
    <!-- Calcite Maps Bootstrap -->
    <link rel="stylesheet" href="https://esri.github.io/calcite-maps/dist/css/calcite-maps-bootstrap.min-v0.10.css">
    <!-- Calcite Maps -->
    <link rel="stylesheet" href="https://esri.github.io/calcite-maps/dist/css/calcite-maps-arcgis-4.x.min-v0.10.css">
    <!--link rel="stylesheet" href="../../dist/css/calcite-maps.min-v0.10.css"-->
    <!-- works -->
    <!-- ArcGIS JS 4 -->
    <link rel="stylesheet" href="https://js.arcgis.com/4.10/esri/css/main.css">
    <link rel="stylesheet" href="../tests/lightbox2/dist/css/lightbox.min.css">
    <style>
        html,
        body {
            margin: 0;
            padding: 0;
            height: 100%;
        .calcite-panels.calcite-panels-left.calcite-bg-custom.calcite-text-light.calcite-bgcolor-dark.panel-group {
            top: 61%;
        .esri-layer-list__item-actions-menu-item:first-of-type {
            display: none;
        .tab {
            margin-left: 4%;
        .esri-legend__layer-caption {
            display: none;
        .esri-legend__message {
            display: none;
        .esri-layer-list__child-toggle+.esri-layer-list__item-label>.esri-layer-list__item-toggle {
            display: none;
        a {
            cursor: pointer;
        .esri-layer-list__item-actions-menu-item--active,
        .esri-layer-list__item-actions-menu-item--active:hover {
            background-color: whitesmoke;
        .calcite-title:before {
            content: url('/apps/jay/tests/UGS-blm.png');
            padding: 6px 12px 0 2px;
            cursor: pointer;
        .esri-layer-list__item-container .tooltiptext {
            visibility: hidden;
            width: 120px;
            background-color: ivory;
            color: #fff;
            text-align: center;
            padding: 5px 0;
            border-radius: 6px;
            position: absolute;
            z-index: 1;
        .esri-layer-list__item-container:hover .tooltiptext {
            visibility: visible;
        .calcite-maps .calcite-search-expander .esri-search__sources-button.esri-widget--button {
            display: block !important;
        .calcite-maps .calcite-search-expanded .esri-menu.esri-search__sources-menu {
    </style>
</head>
<body class="calcite-maps calcite-nav-top">
    <!-- Navbar -->
    <a class="ugs-watermark " href="https://geology.utah.gov"></a>
    <nav class="navbar calcite-navbar navbar-fixed-top calcite-text-light calcite-bg-dark calcite-bgcolor-dark">
        <!-- Menu -->
        <div class="dropdown calcite-dropdown calcite-bg-light calcite-text-dark" role="presentation">
            <a class="dropdown-toggle" role="menubutton" aria-haspopup="true" aria-expanded="false" tabindex="0">
                <div class="calcite-dropdown-toggle">
                    <span class="sr-only">Toggle dropdown menu</span>
                    <span></span>
                    <span></span>
                    <span></span>
                    <span></span>
                </div>
            </a>
            <ul class="dropdown-menu calcite-menu">
                <li><a class="active hidden-md hidden-lg" href="#mapTab" aria-controls="mapTab" role="tab" data-toggle="tab"> 2D</a></li>
                <li><a class="hidden-md hidden-lg" href="#sceneTab" aria-controls="sceneTab" role="tab" data-toggle="tab"> 3D</a></li>
                <li><a role="menuitem" tabindex="0" data-target="#panelInfo" aria-haspopup="true"><span class="esri-icon-notice-round"></span> About</a></li>
                <li><a role="menuitem" tabindex="0" data-target="#panelDisclaimer" aria-haspopup="true"><span class="esri-icon-notice-triangle"></span> Disclaimer</a></li>
                <li><a role="menuitem" tabindex="0" data-target="#panelLegend" aria-haspopup="true"><span class="glyphicon glyphicon-list-alt"></span> Legend</a></li>
                <li><a role="menuitem" tabindex="0" data-target="#panelBasemaps" aria-haspopup="true"><span class="esri-icon-basemap"></span> Basemaps</a></li>
                <!-- <li><a role="menuitem" tabindex="0" data-target="#calciteLocate" id="calciteLocate" aria-haspopup="true"><span class="glyphicon glyphicon-map-marker"></span> Locate</a></li> -->
                <!-- <li><a role="menuitem" tabindex="0" id="calciteToggleNavbar" aria-haspopup="true"><span class="glyphicon glyphicon-fullscreen"></span> Full Map</a></li> -->
            </ul>
        </div>
        <!-- Title -->
        <div class="calcite-title calcite-overflow-hidden">
            <span class="calcite-title-main">Utah Geological Survey</span>
            <span class="calcite-title-divider hidden-xs"></span>
            <span class="calcite-title-sub hidden-xs">Utah Geologic and Mineral Resources</span>
        </div>
        <!-- Nav -->
        <ul class="calcite-nav nav navbar-nav">
            <!-- <li><a id="mapNav" class="hidden-xs hidden-sm" href="#mapTab" aria-controls="mapTab" aria-expanded="true" role="tab" data-toggle="tab" data-tooltip="tip" title="2D View" data-placement="bottom">2D View</a></li>
    <li class="active"><a id="sceneNav" class="hidden-xs hidden-sm" href="#sceneTab" aria-controls="mapTab" role="tab" data-toggle="tab" data-tooltip="tip" title="3D View" data-placement="bottom">3D View</a></li>                   -->
            <li>
                <div class="calcite-navbar-search calcite-search-expander" role="presentation" tabindex="-1">
                    <div id="searchNavDiv" tabindex="0"></div>
                </div>
            </li>
        </ul>
    </nav>
    <!--/.navbar -->
    <!-- Map Container  -->
    <div class="calcite-map calcite-map-absolute">
        <div id="tabContainer" class="tab-content">
            <div id="mapTab" class="tab-pane fade in active" role="tabpanel">
                <div id="mapViewDiv"></div>
            </div>
            <!-- <div id="sceneTab" class="tab-pane fade in active" role="tabpanel">
      <div id="sceneViewDiv"></div>
    </div> -->
        </div>
    </div>
    <!-- Panel Container -->
    <!-- Panel - Legend -->
    <div class="calcite-panels calcite-panels-left calcite-bg-custom calcite-text-light calcite-bgcolor-dark panel-group" role="tablist" aria-multiselectable="true">
        <div id="panelLegend" class="panel collapse in">
            <div id="headingLegend" class="panel-heading" role="tab">
                <div class="panel-title">
                    <a class="panel-toggle" role="button" data-toggle="collapse" href="#collapseLegend" aria-expanded="true" aria-controls="collapseLegend"><span class="glyphicon glyphicon-list-alt" aria-hidden="true"></span><span class="panel-label">Legend</span></a>
                    <a class="panel-close" role="button" data-toggle="collapse" tabindex="0" href="#panelLegend"><span class="esri-icon esri-icon-close" aria-hidden="true"></span></a>
                </div>
            </div>
            <div id="collapseLegend" class="panel-collapse collapse in" role="tabpanel" aria-labelledby="headingLegend">
                <div class="panel-body">
                    <div id="legendDiv"></div>
                </div>
            </div>
        </div>
    </div>
    <div class="calcite-panels calcite-panels-right calcite-bg-custom calcite-text-light calcite-bgcolor-dark panel-group" role="tablist" aria-multiselectable="true">
        <!-- Info Panel -->
        <div id="panelInfo" class="panel collapse in">
            <div id="headingInfo" class="panel-heading" role="tab">
                    <a class="panel-toggle" role="button" data-toggle="collapse" href="#collapseInfo" aria-expanded="true" aria-controls="collapseInfo"><span class="esri-icon-notice-round" aria-hidden="true"></span><span class="panel-label">About</span></a>
                    <a class="panel-close" role="button" data-toggle="collapse" tabindex="0" href="#panelInfo"><span class="esri-icon esri-icon-close" aria-hidden="true"></span></a>
                </div>
            </div>
            <div id="collapseInfo" class="panel-collapse collapse in" role="tabpanel" aria-labelledby="headingInfo">
                    <p><strong>BLM UTAH MINERAL RESOURCES</strong></p>
                    <p align="justify">This web map application was created by the Utah Geological Survey (UGS) in cooperation with the U.S. Bureau of Land Management (BLM) to show geologic resources on BLM land and statewide mineral resources in Utah. Use the links below to download the map data. <br /><br /><a href="https://ugspub.nr.utah.gov/publications/open_file_reports/ofr-695.pdf" target="_blank"><span style="color: blue;"> Utah Mining Districts publication</span></a> <br /><a href="https://geology.utah.gov/docs/zip/Mining_Districts_20190116gdb.zip" target="_blank"><span style="color: blue;"> Utah Mining Districts GIS data</span></a> <br /><a href="https://geology.utah.gov/docs/zip/Utah_IM_GIS.zip" target="_blank"><span style="color: blue;"> Industrial Mineral GIS data</span></a> <br /><br /><strong>Layer Information</strong></p>
                    <p><br />GeoSights on BLM Land</p>
                    <p class="tab" style="padding-left: 20px;">A collection of Utah's lesser-known geologic wonders (from UGS Survey Notes).</p>
                    <p><br />Rockhounding Sites on BLM Land</p>
                    <p class="tab" style="padding-left: 20px;">Utah rockhounding sites (from UGS publication MP-95-4 by Wilson).</p>
                    <p><br /><br /></p>
                </div>
            </div>
        </div>
        <!-- Basemaps Panel -->
        <div id="panelBasemaps" class="panel collapse">
            <div id="headingBasemaps" class="panel-heading" role="tab">
                    <a class="panel-toggle collapsed" role="button" data-toggle="collapse" href="#collapseBasemaps" aria-expanded="false" aria-controls="collapseBasemaps"><span class="esri-icon-basemap" aria-hidden="true"></span><span class="panel-label">Basemaps</span></a>
                    <a class="panel-close" role="button" data-toggle="collapse" tabindex="0" href="#panelBasemaps"><span class="esri-icon esri-icon-close" aria-hidden="true"></span></a>
                </div>
            </div>
            <div id="collapseBasemaps" class="panel-collapse collapse" role="tabpanel" aria-labelledby="headingBasemaps">
                    <select id="selectBasemapPanel" class="form-control">
                        <option value="streets" data-vector="streets-vector">Streets</option>
                        <option value="satellite" data-vector="satellite">Satellite</option>
                        <option value="hybrid" data-vector="hybrid">Hybrid</option>
                        <option value="national-geographic" data-vector="national-geographic">National Geographic</option>
                        <option value="topo" data-vector="topo-vector" selected="">Topographic</option>
                        <option value="gray" data-vector="gray-vector">Gray</option>
                        <option value="dark-gray" data-vector="dark-gray-vector">Dark Gray</option>
                        <option value="osm" data-vector="osm">Open Street Map</option>
                        <option value="dark-gray" data-vector="streets-night-vector">Streets Night</option>
                        <option value="streets" data-vector="streets-navigation-vector">Streets Mobile</option>
                    </select>
                </div>
            </div>
        </div>
        <!-- Grid panelSearch panel -->
        <div id="panelGrid" class="panel collapse">
                    <a class="panel-toggle" role="button" data-toggle="collapse" href="#collapseGrid" aria-expanded="false" aria-controls="collapseGrid"><span class="glyphicon glyphicon-list-alt" aria-hidden="true"></span><span class="panel-label">Search Results</span></a>
                    <a class="panel-close" role="button" data-toggle="collapse" data-target="#panelGrid"><span class="esri-icon esri-icon-close" aria-hidden="true"></span></a>
                </div>
            </div>
            <div id="collapseGrid" class="panel-collapse collapse" role="tabpanel" aria-labelledby="headingGrid">
                    <div id="grid"></div>
                    <!--  <div id="results" class="results"></div>  -->
                </div>
            </div>
        </div>
        <!-- Attribute Details panel -->
        <div id="panelDetails" class="panel collapse">
                    <a class="panel-toggle" role="button" data-toggle="collapse" href="#collapseDetails" aria-expanded="true" aria-controls="collapseDetails"><span class="glyphicon glyphicon-list-alt" aria-hidden="true"></span><span class="panel-label" id="details">All Available Sample Data</span></a>
                    <a class="panel-close" role="button" data-toggle="collapse" data-target="#panelDetails"><span class="esri-icon esri-icon-close" aria-hidden="true"></span></a>
                </div>
            </div>
            <div id="collapseDetails" class="panel-collapse collapse" role="tabpanel" aria-labelledby="headingDetails">
                    <div id="attDetails"></div>
                </div>
            </div>
        </div>
        <!-- Disclaimer panel -->
        <div id="panelDisclaimer" class="panel collapse">
                    <a class="panel-toggle" role="button" data-toggle="collapse" href="#collapseDisclaimer" aria-expanded="true" aria-controls="collapseDisclaimer"><span class="esri-icon-notice-triangle" aria-hidden="true"></span><span class="panel-label">Disclaimer</span></a>
                    <a class="panel-close" role="button" data-toggle="collapse" data-target="#panelDisclaimer"><span class="esri-icon esri-icon-close" aria-hidden="true"></span></a>
                </div>
            </div>
            <div id="collapseDisclaimer" class="panel-collapse collapse" role="tabpanel" aria-labelledby="headingDisclaimer">
                    <p style="text-align: justify;">Although this product represents the work of professional scientists, the Utah Department of Natural Resources, Utah Geological Survey and U.S. Department of the Interior, U.S. Bureau of Land Management make no warranty, expressed or implied, regarding its suitability for any particular use. The Utah Department of Natural Resources, Utah Geological Survey, and U.S. Department of the Interior, U.S. Bureau of Land Management shall not be liable under any circumstances for any direct, indirect, special, incidental, or consequential damages with respect to claims by users of this product. The Utah Geological Survey and U.S. Bureau of Land Management do not guarantee accuracy or completeness of the data. The views and conclusions contained in this document are those of the authors and should not be interpreted as necessarily representing the official policies, either expressed or implied, of the U.S. Government. Persons or agencies using these data specifically agree not to misrepresent the data, nor to imply that changes they made were approved by the Utah Geological Survey, and should indicate the data source and any modifications made on plots, digital copies, derivative products, and in metadata. The authors' determinations of resource potential DO NOT imply a determination of locatability for claim-staking purposes. The authors' determinations of resource potential also DO NOT imply potential for development of mineral resources.</p>
                </div>
            </div>
        </div>
    </div> <!-- /.calcite-panels -->
    <script src="https://momentjs.com/downloads/moment.js"></script>
    <script src="../tests/lightbox2/dist/js/lightbox-plus-jquery.min.js"></script>
    <script type="text/javascript">
        var dojoConfig = {
            packages: [{
                    location: "https://esri.github.io/calcite-maps/dist/vendor/dojo-bootstrap"
                    location: "https://esri.github.io/calcite-maps/dist/js/dojo"
    </script>
    <script src="https://js.arcgis.com/4.10/"></script>
    <script>
var app;
require([
    "esri/Map",
    "esri/Basemap",
    "esri/Graphic",
    "dojo/query",
    "dojo/request",
    // Calcite-maps
    // Bootstrap
    "bootstrap/Tab",
    "dojo/on",
    "dojo/dom",
    "dojo/domReady!"
    // App
    app = {
        zoom: 8,
        basemap: "topo",
        viewPadding: {
            top: 50,
            bottom: 0
        uiPadding: {
            top: 15,
            bottom: 15
        map: null,
        mapView: null,
        sceneView: null,
        activeView: null,
    // Map
    app.map = new Map({
    // 2D View
        map: app.map,
        zoom: 8,
        ui: {
    // 3D View
        map: app.map,
        zoom: app.zoom,
        center: app.center,
        ui: {
        } else {
    // Views
        } else {
    // Search Widget
    // Active view
                console.log("poop");
            }, 500);
                item.panel = {
                    content: "legend",
                    open: true
            layer = bentonite;
            layer = gypsum;
            layer = limestone;
        } else {
            layer = dolomite;
    //Popup Templates
        var content = "";
        return content;
        var content = "";
            if (data.Picture) {
        return content;
        var content = "";
                    style: 'currency',
                    currency: 'USD',
                }) + "</b><br>";
        return content;
        var content = "";
            if (data.AGE) {
        return content;
        var content = "";
            if (data.Age) {
        return content;
        displayType: "list"
    //renderers
        symbol: {
            outline: null
        symbol: {
            outline: null
        outFields: ["*"],
        popupTemplate: {
        visible: false,
        outFields: ["*"],
        popupTemplate: {
        visible: false,
        outFields: ["*"],
        opacity: 0.5,
        popupTemplate: {
            content: [{
                type: "text",
                type: "attachments"
        visible: true,
        title: "Bentonite",
        opacity: 0.5,
        outFields: ["*"],
        popupTemplate: {
        visible: false,
        title: "Dolomite",
        outFields: ["*"],
        opacity: 0.5,
        popupTemplate: {
        visible: false,
        title: "Gypsum",
        outFields: ["*"],
        opacity: 0.5,
        popupTemplate: {
        visible: false,
        title: "Limestone",
        outFields: ["*"],
        opacity: 0.5,
        popupTemplate: {
        visible: false,
        visible: true,
        symbol: {
                weight: "bold"
        outFields: ["*"],
        opacity: 0.15,
        visible: true,
        symbol: {
                weight: "bold"
        title: "Counties",
        listMode: "hide",
        opacity: 0.5,
        visible: true,
  </script>
   <!-- Bootstrap core JavaScript
    <!-- Placed at the end of the document so the pages load faster -->
    <!-- jQuery (for Bootstrap's JavaScript plugins). NOTE: You can also use pure Dojo. See examples. -->
    <script src="https://ajax.googleapis.com/ajax/libs/jquery/1.11.3/jquery.min.js"></script>
    <!-- Include all  plugins or individual files as needed
    <script src="//maxcdn.bootstrapcdn.com/bootstrap/3.3.5/js/bootstrap.min.js"></script>  -->
</body>
</html>
Jay,
            if(eyeArr.length){
          }, 500);
JayHill
Thanks Robert
the map method is new to me, but I see it was adding a new title to each item in the array. could I use the map method to change existing titles in each node as well?
Jay,
    The map method is a method available for any js array object and is similar to forEach (meaning it loops over the array). Sure if you query for the titles class like query(".esri-layer-list__item-title");
JayHill
Appreciate your help!
