adding "zoom to" on search result
998
05-07-2013 08:04 AM
GyeyoungChoi
Hello,
I've used http://help.arcgis.com/en/webapi/javascript/arcgis/jssamples/find_nomap.html
this find task but now I want to add "zoom to" with my result.
However I couldn't find examples or right api
Can anyone help me with this?
Thank you,
Jack
ShreyasVakil
While defining the findTask you need to make sure the returnGeometry is set to true so that you can zoom. By default it is false.
Once you have the geometry on the client side, you can either use the centerAndZoom method or use the map.setExtent depending upon the geometry you receive.(point or polygon)
VinayBansal
You may get an idea from this sample.
http://help.arcgis.com/en/webapi/javascript/arcgis/jssamples/find_map_datagrid.html
Sample shows find task data in grid and then zooms to the results.
Vinay Bansal
MarcoAmaya
hi
if you did the zoom to search result , pleas share it . i need to do some like that.
Thanks
GyeyoungChoi
hi
Thanks
I haven't succeed yet
        findTask = new esri.tasks.FindTask("http://localhost:6080/arcgis/rest/services/FC/AapInfo/MapServer");
        dojo.connect(map, "onLoad", function() {
          findParams = new esri.tasks.FindParameters();
          findParams.returnGeometry = true;
          findParams.layerIds = [2];
          findParams.searchFields = ["OBJECTID","Number","Abbrev","CampusCode"];
          findParams.outSpatialReference = map.spatialReference;
          console.log("find sr: ", findParams.outSpatialReference);
function doFind() {
         findParams.searchText = dojo.byId("searchField").value;
        findTask.execute(findParams,showResults);
      function showResults(results) {
        map.graphics.clear();
        var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([98,194,204]), 2), new dojo.Color([98,194,204,0.5]));
        var items = dojo.map(results,function(result){
          var graphic = result.feature;
          graphic.setSymbol(symbol);
          map.graphics.add(graphic);
          return result.feature.attributes;
        var data = {
          identifier: "OBJECTID",
          label: "OBJECTID",
          items: items
        store = new dojo.data.ItemFileReadStore({ data:data });
  grid.setStore(store);
        map.centerAndZoom(center, zoom);
      function onRowClickHandler(evt){
        var clickedTaxLotId = grid.getItem(evt.rowIndex).OBJECTID;
        var selectedTaxLot;
        dojo.forEach(map.graphics.graphics,function(graphic){
          if((graphic.attributes) && graphic.attributes.OBJECTID === clickedTaxLotId){
            selectedTaxLot = graphic;
   //alert(selectedTaxLot);
            return;
        var taxLotExtent = selectedTaxLot.geometry.getExtent();
        map.setExtent(taxLotExtent);
<input type="text" id="searchField" size="30" value="" /><button data-dojo-type="dijit.form.Button"  onClick="doFind();" value="Search">
        Search
      </button>
<table data-dojo-type="dojox.grid.DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'10px'">
      <thead>
        <tr>
          <th field="Number" width="50">Num</th>
          <th field="Abbrev" width="50">Abbr</th>
          <th field="CampusCode" width="50">Camp</th>
        </tr>
      </thead>
    </table>
All i can get is result highlighted on the map but no return on "dojo grid " at the <table>
if someone knows why please HELP!
