Add WMTS Layers with API JS 3
4423
6
10-11-2022 06:17 AM
ThibaultPetiet
As part of a GIS web application, using the ArcGIS API for JavaScript version 3.19, I would like to add a WMTS Layer.
For this, I copied the code provided by the documentation : documentation. https://developers.arcgis.com/javascript/3/jssamples/layers_wmtslayer.html
url = "https://wxs.ign.fr/parcellaire/geoportail/wmts?service=WMTS&REQUEST=GetCapabilities"
var layerInfo = new esri.layers.WMTSLayerInfo({
	identifier: "PCI",
layerIndex = 1;
var options = {
	layerInfo: layerInfo
layer = new esri.layers.WMTSLayer(url, options);
this.map.addLayer(layer, layerIndex);
But the addition in the map does not go well. I get an error
The WMTS capabilities XML is not valid.
Looking more closely at the GetCapabilities request, I observe that in the url, the end "/1.0.0/GetCapabilities.xml" seems to be extra.
Is there a way to not have this addition, to no longer encounter this problem?
JoelBennett
MVP Regular Contributor
I think the first problem is that you shouldn't specify the query string in the URL as seen on line 1.
Instead, it should just be
url = "https://wxs.ign.fr/parcellaire/geoportail/wmts";
You might also consider the documentation in the constructor for the resourceInfo object.  When using WMTS layers, I've preferred specifying the necessary resourceInfo properties up front so that the GetCapabilities request can be bypassed entirely, and the application can just go immediately to rendering the tiles.  The necessary information to specify within resourceInfo can be gathered manually from the contents of the GetCapabilities response.
ThibaultPetiet
Thank you for your reply. I was able to add the resource info object. And I tried to rebuild TileInfo from the GetCapabilities data.
var tileInfo1 = new esri.layers.TileInfo({
	"dpi": 96,
	"spatialReference": this.map.spatialReference,
	"format": "image/png",
	"origin": {
		"x": 0.0000000000000000,
		"y": 12000000.0000000000000000,
	"lods": lods,
	format: "image/png",
	fullExtent: this.map.extent,
	initialExtent : this.map.extent,
	identifier: "CADASTRALPARCELS.PARCELS",
	tileInfo: tileInfo1,
	tileMatrixSet: "LAMB93",
	title: "Parcelles cadastrales"
var resourceInfo = {
	version: "1.0.0",
	layerInfos: [layerInfo],
var options = {
	resourceInfo: resourceInfo,
	serviceMode: "KVP",
The layer object is well created but the addition to the map does not take place. Do you think it's a parameter issue or something else ?
JoelBennett
I'm afraid my time available to help is very limited.  The best I might offer at this point is what I would try next if it were me.  I would avoid specifying parameters in the constructor for TileInfo since it's not well documented (and maybe even the same for WMSTileInfo).
For example, instead of something like:
var tileInfo = new TileInfo({
	propertyName1: propertValue1,
	propertyName2: propertValue2
maybe something like:
var tileInfo = new TileInfo();
tileInfo.propertyName1 = tileInfo.propertyValue1;
tileInfo.propertyName2 = tileInfo.propertyValue2;
In doing that, be sure to use fully instantiated objects as well.  For example, when specifying the origin property, I recommend using an Point object instance with its spatialReference specified.  The way you presently have it as an object literal, I'm not sure what the API would do, and since there's no spatialReference specified, it would default to WGS 84 (4326), but I can tell you're not trying to use that.
Another example, is that in the "format" property for TileInfo, the documentation for that property accepts the values "png8", "png24", "png32", and "jpg", but you have "image/png".
I hope that helps...I apologize for not being able to do more.
Bertrand_Laurancin
Hello,
It works like this :
https://codepen.io/blaurancin/pen/abGeWZJ
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Add WMTS Layer</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.41/esri/css/esri.css">
  <style>
    html,
    body,
    #mapDiv {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script src="https://js.arcgis.com/3.41/"></script>
  <script>
    require([
      "esri/map", "esri/layers/WMTSLayer", "esri/layers/WMTSLayerInfo",
      "esri/geometry/Extent", "esri/layers/TileInfo", "esri/SpatialReference", "esri/geometry/Point",
      "dojo/domReady!"
    ], function(
      Map, WMTSLayer, WMTSLayerInfo,
      Extent, TileInfo, SpatialReference, Point,
      // parser.parse();
      var bounds = new Extent({
        "xmin": 14000,
        "ymin": 6000000,
        "xmax": 1200000,
        "ymax": 8100000,
        "spatialReference": {
          "wkid": 2154
      var map = new Map("mapDiv", {
        extent: bounds
      map.spatialReference = new SpatialReference({
        wkid: 2154
      // les paramètres tile matrix
        "dpi": 96,
        "format": "png",
        "spatialReference": new SpatialReference({
          "wkid": 2154
        "rows": 256,
        "cols": 256,
        "origin": {
          "x": 0,
          "y": 12000000
        "lods": [{
          "level": "0",
          "scale": 373497230.5353357571875677,
          "resolution": 104579.2245498940
          "level": "1",
          "scale": 186705472.6921089404495433,
          "resolution": 52277.5323537905
          "level": "2",
          "scale": 93341025.2806978682347108,
          "resolution": 26135.4870785954
          "level": "3",
          "scale": 46667469.2207142901243060,
          "resolution": 13066.8913818000
          "level": "4",
          "scale": 23332959.3004053602435306,
          "resolution": 6533.2286041135
          "level": "5",
          "scale": 11666284.0159382160591122,
          "resolution": 3266.5595244627
          "level": "6",
          "scale": 5833092.8735621436167094,
          "resolution": 1633.2660045974
          "level": "7",
          "scale": 2916534.1249500003143567,
          "resolution": 816.6295549860
          "level": "8",
          "scale": 1458263.9809885714915936,
          "resolution": 408.3139146768
          "level": "9",
          "scale": 729131.2196817857459905,
          "resolution": 204.1567415109
          "level": "10",
          "scale": 364565.417082857155833,
          "resolution": 102.0783167832
          "level": "11",
          "scale": 182282.6603450000154965,
          "resolution": 51.0391448966
          "level": "12",
          "scale": 91141.3181225000130965,
          "resolution": 25.5195690743
          "level": "13",
          "scale": 45570.6560485714301016,
          "resolution": 12.7597836936
          "level": "14",
          "scale": 22785.3272714285733418,
          "resolution": 6.3798916360
      var tileInfo2 = new TileInfo({
        dpi: 96,
        height: 256,
        lods: [{
            "level": 0,
            "resolution": 2000.0000000000002,
            "scale": 7559040
            "level": 1,
            "resolution": 1000.0000000000001,
            "scale": 3779520
            "level": 2,
            "resolution": 500.00000000000006,
            "scale": 1889760
            "level": 3,
            "resolution": 250.00000000000003,
            "scale": 944880
            "level": 4,
            "resolution": 100,
            "scale": 377952
            "level": 5,
            "resolution": 50,
            "scale": 188976
            "level": 6,
            "resolution": 25,
            "scale": 94488
            "level": 7,
            "resolution": 9.9999470832275,
            "scale": 37795
            "level": 8,
            "resolution": 5.000105833545001,
            "scale": 18898
            "level": 9,
            "resolution": 2.5000529167725003,
            "scale": 9449
            "level": 10,
            "resolution": 1.0001270002540006,
            "scale": 3780
            "level": 11,
            "resolution": 0.5000635001270003,
            "scale": 1890
            "level": 12,
            "resolution": 0.26458386250105836,
            "scale": 1000
            "level": 13,
            "resolution": 0.13229193125052918,
            "scale": 500
            "level": 14,
            "resolution": 0.06614596562526459,
            "scale": 225
            "level": 15,
            "resolution": 0.026458386250105836,
            "scale": 100
            "level": 16,
            "resolution": 0.013229193125052918,
            "scale": 50
        origin: new Point(0.0000000000000000, 12000000.0000000000000000, new SpatialReference(2154)),
        spatialReference: new SpatialReference(2154),
        width: 256
      var tileInfo3 = new TileInfo({
        dpi: 96,
        height: 256,
        lods: [{
          "level": 0,
          "scale": 395260061.290938,
          "resolution": 104579.22454989403
          "level": 1,
          "scale": 197584374.25054678,
          "resolution": 52277.532353790506
          "level": 2,
          "scale": 98779793.68288027,
          "resolution": 26135.487078595404
          "level": 3,
          "scale": 49386676.08869292,
          "resolution": 13066.891381800004
          "level": 4,
          "scale": 24692517.558854178,
          "resolution": 6533.228604113501
          "level": 5,
          "scale": 12346051.74600076,
          "resolution": 3266.5595244627007
          "level": 6,
          "scale": 6172973.875643717,
          "level": 7,
          "scale": 3086473.908608504,
          "level": 8,
          "scale": 1543233.6932666455,
          "level": 9,
          "scale": 771616.0309073386,
          "resolution": 204.15674151090005
          "level": 10,
          "scale": 385807.811464063,
          "level": 11,
          "scale": 192903.8547273071,
          "resolution": 51.03914489660001
          "level": 12,
          "scale": 96451.91461152758,
          "resolution": 25.519569074300005
          "level": 13,
          "scale": 48225.954117543304,
          "level": 14,
          "scale": 24112.976262047247,
          "resolution": 6.379891636000001
          "level": 15,
          "scale": 12056.487931842521,
          "resolution": 3.1899457653
          "level": 16,
          "scale": 6028.243916220473,
          "resolution": 1.5949728695
          "level": 17,
          "scale": 3014.121945826772,
          "resolution": 0.7974864315000002
          "level": 18,
          "scale": 1507.0609697007874,
          "resolution": 0.39874321490000003
          "level": 19,
          "scale": 753.5304842834646,
          "resolution": 0.1993716073
        width: 256
      // console.log(tileInfo2);
      var tileExtent2 = new Extent(14000, 6000000, 1200000, 8100000, new SpatialReference({
        wkid: 2154
      var layerInfo2 = new WMTSLayerInfo({
        tileInfo: tileInfo,
        fullExtent: tileExtent2,
        initialExtent: tileExtent2,
        identifier: "CADASTRALPARCELS.PARCELS.L93",
        format: "png",
        style: "normal"
      // console.log(layerInfo2);
        version: "1.0.0",
        layerInfos: [layerInfo2],
        copyright: "IGN"
      // console.log(resourceInfo);
      var options = {
        serviceMode: "KVP",
        layerInfo: layerInfo2
      // console.log(options);
      var wmtsLayer = new WMTSLayer("https://wxs.ign.fr/lambert93/geoportail/wmts", options);
      console.log(wmtsLayer);
      map.addLayer(wmtsLayer);
      console.log("map.spatialReference", map.spatialReference)
      console.log("wmtsLayer", wmtsLayer)
      for (var i = 0; i < wmtsLayer.layerInfos[0].tileInfo.lods.length; i++) {
        console.log(i + ":");
        console.log("endTileCol:" + wmtsLayer.layerInfos[0].tileInfo.lods[i].endTileCol);
        console.log("endTileRow:" + wmtsLayer.layerInfos[0].tileInfo.lods[i].endTileRow);
        console.log("level:" + wmtsLayer.layerInfos[0].tileInfo.lods[i].level);
        console.log("resolution:" + wmtsLayer.layerInfos[0].tileInfo.lods[i].resolution);
        console.log("scale:" + wmtsLayer.layerInfos[0].tileInfo.lods[i].scale);
        console.log("startTileCol:" + wmtsLayer.layerInfos[0].tileInfo.lods[i].startTileCol);
        console.log("startTileRow:" + wmtsLayer.layerInfos[0].tileInfo.lods[i].startTileRow);
  </script>
<body>
  <div id="mapDiv">
  </div>
</body>
</html>
Bertrand_Laurancin
Or like this :
https://codepen.io/blaurancin/pen/VwxNPgW
<html>
<head>
  <style>
    html,
    body,
    #mapDiv {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script>
    require([
      "esri/map",
      "esri/config",
      "dojo/domReady!"
    ], function(
      Map, WMTSLayer, WMTSLayerInfo, TileInfo, SpatialReference, Extent, Point, esriConfig
      esriConfig.defaults.io.corsEnabledServers.push("wxs.ign.fr", "codepen.io");
      const extent2154 = new Extent({
        "xmin": 14000,
        "ymin": 6000000,
        "xmax": 1200000,
        "ymax": 8100000,
          "wkid": 2154
      const map = new Map("mapDiv", {
        // basemap: "topo-vector",
        // center: [2.4641536, 48.8210432], //27.988056, 86.925
        zoom: 18,
        extent: extent2154
        wkid: 2154
      const tileInfo = new TileInfo({
        "dpi": 96,
        "format": "png",
          "wkid": 2154
        "rows": 256,
        "cols": 256,
        "origin": {
          "x": 0,
          "y": 12000000
        "lods": [{
          "level": "0",
          "level": "1",
          "level": "2",
          "level": "3",
          "level": "4",
          "level": "5",
          "level": "6",
          "level": "7",
          "level": "8",
          "level": "9",
          "level": "10",
          "level": "11",
          "level": "12",
          "level": "13",
          "level": "14",
      // map._params.tileInfo = tileInfo3;
      // map.__tileInfo = tileInfo3;
      const url = "https://wxs.ign.fr/lambert93/geoportail/wmts";
      const layerInfo = new esri.layers.WMTSLayerInfo({
        tileInfo: tileInfo,
        format: "png",
        fullExtent: extent2154,
        initialExtent: extent2154,
        style: "normal"
      const options = {
        serviceMode: "KVP",
        minScale: 100000000,
        maxScale: 200,
      const aLayers = [];
      // ESRI basemaps
      const strEsriUrl = "https://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer";
      const esriLayer = new esri.layers.ArcGISTiledMapServiceLayer(strEsriUrl);
      const ignWmtsLayer = new esri.layers.WMTSLayer(url, options);
      console.log("esriLayer", esriLayer)
      console.log("ignWmtsLayer", ignWmtsLayer)
      // console.log("map", map)
      aLayers.push(ignWmtsLayer);
      // aLayers.push(esriLayer);
      map.addLayers(aLayers);
  </script>
</head>
<body>
  <div id="mapDiv"></div>
</body>
</html>
Bertrand_Laurancin
