Add watermark
1150
11-14-2014 09:09 AM
AdrianMarsden
Honored Contributor
Hi
I have used code derived from
http://warblingdiode.blogspot.co.uk/2010/02/watermarking-your-maps-with-esri-arcgis.html#comment-for...
Before quite well.
I have now created a new site, and am being good, using AMD and stuff.  Yet it fails
This is the code I use, all in the function thingy of the initial require.
    dojo.declare("myScripts.WatermarkLayer", DynamicMapServiceLayer, {
        startExtent: new Extent({ xmin: 0, ymin: 0, xmax: 700000, ymax: 1300000, spatialReference: { wkid: 27700 } }),
        //construct the layer
        constructor: function (args) {
            this.initialExtent = this.fullExtent = this.startExtent;
            this.spatialReference = this.initialExtent.spatialReference;
            dojo.mixin(this, args);
            //set layer loaded property and fire onLoad event
            this.loaded = true;
            this.onLoad(this);
        getImageUrl: function (extent, width, height, callback) {
            try {
                callback(this.url);
            catch (ex) {
                console.debug("Error getting Watermark image. " + ex.message);
        _errorCallback: function (err) {
            console.error(err.message);
    wm = new myScripts.WatermarkLayer({ watermarkUrl: "Logo.png" })
    wm.setOpacity(1);
    map.addLayer(wm);
    console.debug(wm)
    console.debug(map)
It doesn't error - the console of the wm object shows what I would expect.
The console of the map object shows the lyaer added.
yet I get
GET http://dev/test/null 404 (Not Found)
Error - and I get this every time I zoom in or out, which indicates it isn't finding the watermark image
It's late on a Friday - if anyone thinks they can help I can put all code live somewhere next week
ACM
AdrianMarsden
Honored Contributor
Slly me - the code wanted  different parameters for tiled (which I used before) and dynamic.  Dynamic only wanted url - leaving original post there as a pointer for others
