Add Text to the Sketch Widget
4321
10-19-2021 08:53 AM
MichaelBoschert
Hey,
i would like to offer the users the possibility to add some text to the map.
I tried with the following code https://community.esri.com/t5/arcgis-api-for-javascript-questions/how-to-add-draw-widget-along-with-...
That's works fine but it's done for API4.9, not 4.21. When changing to 4.21 in the "<script> part" it runs into an error or several functions don't work well.I tried to figure out the difference for a while but didn't find any solution.
Can someone help me? Maybe someone also finds an easier or another way to realize my issue...
Noah-Sager
What is your goal? You can use Map Notes to quickly add text to the map:
https://developers.arcgis.com/javascript/latest/sample-code/layers-mapnoteslayer/
You can also extend the Sketch widget using the ViewModel, and assign a TextSymbol to the pointSymbol property:
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Sketch-SketchViewModel.ht...
Noah-Sager
MichaelBoschert
Thanks @Noah-Sager
My goal is to create a sketch widget with the possibility to add notes to the map using the API 4.21 - not 4.9 as it was used in my example.
All in one exactly what your example does... Thanks a lot, this will work for me!
Noah-Sager
Glad to hear it @MichaelBoschert. Please feel free to mark my post as the solution if it answered your question.
