Add Stream Layer as Source in Search Widget
1316
08-04-2022 01:02 AM
ElviraForslund
I have trouble getting the Search Widget to work with a Stream Layer as a Source. I have followed this Search widget with multiple sources | Sample Code | ArcGIS API for JavaScript 4.24 | ArcGIS Develope... sample code and get the widget to work with a Feature Layer, but not with the Stream Layer.
Does the Search Widget support Stream Layers as a source? Or is there something wrong with the Fields in my  Stream Layer? I can add that I get no errors when I run the code, the Search function just don't find anything from my Stream Layer.
I will paste the current code where the Feature Layer as a source work but not the Stream Layer.
Thank you in advance for any help.
Code: (removed after edit)
BjornSvensson
Esri Alum
Hi Elvira,
No, the Search widget does not work with StreamLayer.
See https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Search.html
BjornSvensson
Esri Alum
Hi Elvira,
