add shapefile (not .zip) javascript 4.15
1312
05-07-2020 02:53 AM
deleted-user-VQ40NmU7Vt6N
Hello everyone
I am using a Javascript API 4.15 for Arcgis.
I would like to add a shapefile to my map. I don't want to create a .zip file, just add a shapefile using .shp .dbf .shx and .prj as inputs.
Someone knows any code example for this??
Thanks!!!
RobertScheitlin__GISP
Isaac,
You will not find any example of this because a shapefile is make up of 3 to 11 or more files (thus the use of a zip).
Isaac,
