add Radar data to esri map using javascript
1594
07-24-2019 06:54 AM
YaoYu
Hi, Guys,
really need help on this one... i am trying to add a layer of radar data(image from web map service) to esri map using javascript, below is the URL where the image can be accessed. any one can provide me a solid an example how to do it... or any suggestion how should i do it. i googled but no luck so far. thanks
https://geo.weather.gc.ca/geomet/?lang=en&SERVICE=WMS&REQUEST=GetMap&VERSION=1.3.0&LAYERS=RADAR_1KM_RRAI&STYLES=RADARURPPRECIPR14&FORMAT=image%2Fpng&TRANSPARENT=true&HEIGHT=256&WIDTH=256&UPPERCASE=true&SLD_VERSION=1.1.0&KEEPBUFFER=2&ZINDEX=8&TIME=2019-07-23T15%3A30%3A00Z&CRS=EPSG%3A3857&BBOX=-12523442.714243276,2504688.5428486555,-10018754.171394622,5009377.08569731
RobertScheitlin__GISP
Yao,
   You need to use a WMSLayer for this. You did not specify if you were using 4.x or 3.x of the API though.
YaoYu
thanks for your reply, we use 3.2x version of esri
