Add custom headers to layer requests
4619
08-08-2016 04:05 AM
LukasKalt
Is it possible to add custom HTTP headers to every layer request (p.e. WMTSLayer)? I'd like to add the referer header because otherwise the WMTS Service doesn't  delivier the image.
ReneRubalcava
Esri Frequent Contributor
In 3.x you can use esriRequest.setRequestPreCallback()
esri/request | API Reference | ArcGIS API for JavaScript 3.17
This will let you modify the request before it is sent.
RiccardoKlinger2
Unfortunately I wasn't able to alter the Referer item (translated to English):
"Attempt to use a forbidden header was rejected: Referer"
