Add Bing Tile Layer which uses quadkey
1500
04-15-2024 05:01 AM
François-XavierHays
I am trying to add a web tile service that was made through Bing tiles and using the quadkey system. I have a tile API which works in QGIS with the {q} parameter instead of {x}/{y}/{z}.
I have created a custom BaseTileLayer as below, but doesn't seem to work properly:
let quadKey= function (x, y, z) {
  var quadKey = [];
  for (var i = z; i > 0; i--) {
      var digit = '0';
      var mask = 1 << (i - 1);
      if ((x & mask) != 0) {
          digit++;
      if ((y & mask) != 0) {
          digit++;
          digit++;
      quadKey.push(digit);
  return quadKey.join('');
let MyCustomTileLayer = BaseTileLayer.createSubclass({
  // properties of the custom tile layer
  properties: {
    urlTemplate: null,
 // override getTileUrl()
 // generate the tile url for a given level, row and column
 getTileUrl: function (level, row, col) {
   return this.urlTemplate.replace("{q}", quadKey(col,row,level));
const  NewLayer = new MyCustomTileLayer({
  urlTemplate: "****/{q}?apikey=****"
Would you have any idea how to proceed?
