Access Layer Datasource of a MapService From REST
6259
04-08-2015 02:17 AM
RamiGhali2
Hello,
I have a published mapservice. Using Javascript APIs, I want to get the datasource (Featureclass name) of a specific featurelayer in that mapservice. Is it possible ?
Rami.
Tags (1)
RobertScheitlin__GISP
Rami,
   I have wanted to do the same and that information is just not available for the REST endpoint.
RamiGhali2
I've come up with the following workaround:
I've created a Python script that can get the datasource of a featurelayer from a mapservice.
Then I've shared this script as a Geoprocessing service that can be consumed via REST or ArcGIS API e.g. ArcGIS API for Javascript.
pythontoolbox​
Here is the full script. It's a Python toolbox.
#====================================Python Toolbox===================================
# Name:        GetLayerDataSource
# Purpose:      A script that get the dataset name (Full path of the featureclass) of a layer in a map service.
# Author:      rami.ghali
# Created:     20/04/2015
# How to use:
#    1- At [GetLayerDataSource], apply your modifications to set the proper values of the AGS name, port, uname, and password.
#    2- Test the tool
#    3- Share the tool as a geoprocessing service
#    4- Consume the shared Geoprocessing service via ArcGIS API to get the dataset names of layers in a mapservice.
import arcpy
import httplib, urllib
import json,sys,os
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the
        .pyt file)."""
        self.label = "GetDataSource"
        self.alias = ""
        # List of tool classes associated with this toolbox
        self.tools = [GetLayerDataSource]
class GetLayerDataSource(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Get Layer DataSource"
        self.description = "Get datasource of featurelayer"
        self.canRunInBackground = False
    def getParameterInfo(self):
        """Define parameter definitions"""
        in_mapservice_name = arcpy.Parameter(displayName="Mapservice Name",name="in_mapservice_name",
                          datatype="String",parameterType="Required",direction="Input")
        in_mapservice_name.value = ""
        in_layer_names = arcpy.Parameter(displayName="Layer Names",name="in_layer_names",
        in_layer_names.value = ""
        out_response = arcpy.Parameter(displayName="Response",name="out_response",
                          datatype="String",parameterType="Derived",direction="Output")
        params = [in_mapservice_name,in_layer_names,out_response]
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        """The source code of the tool."""
        #Read input parameters
        arcpy.AddMessage("Reading input parameters")
        in_mapservice_name = "AdminAreasNOC_EN"#parameters[0].valueAsText
        in_layer_names = "Emirate_District,AreaNames"#parameters[1].valueAsText
        #You can read the following values from a config file
        serverName = "192.168.9.30"
        serverPort = "6080"
        serverUName = "siteadmin"
        serverPwd = "Pa$$w0rd"
        response = []
        datasetName = ""
        try:
            if not in_layer_names or not in_mapservice_name:
                arcpy.AddMessage("Invalid input parameters")
            else:
                #Get Filepath of the map service
                filePath = GetMapServiceFilePath(serverName,serverPort,serverUName,serverPwd,in_mapservice_name)
                if filePath and os.path.exists(filePath.replace("msd","mxd")):
                    arcpy.AddMessage("MapDocument path is valid")
                    mxd = arcpy.mapping.MapDocument(filePath.replace("msd","mxd"))
                    if mxd:
                        arcpy.AddMessage("MapDocument has been loaded")
                        if "," in in_layer_names:
                            lst_layer_names = in_layer_names.split(",")
                        else:
                            lst_layer_names.append(in_layer_names)
                        for layer_name in lst_layer_names:
                            lyr = arcpy.mapping.ListLayers(mxd,layer_name)[0]
                            datasetName = ""
                            if lyr:
                                if lyr.supports("datasetName"):
                                    datasetName = lyr.datasetName
                                del lyr
                            else:
                                arcpy.AddMessage("Couldn't load layer {0}".format(layer_name))
                            response.append({'layer': layer_name,'datasetName':datasetName})
                        del mxd
                        json.dumps(response)
        #If an error occurs while running a tool
        except arcpy.ExecuteError:
            arcpy.AddMessage(arcpy.GetMessages(0))
            arcpy.AddMessage(arcpy.GetMessages(1))
            arcpy.AddMessage(arcpy.GetMessages(2))
        #If any other error occurs
        except Exception as e:
            arcpy.AddMessage(str(e))
        parameters[2].value = str(response)
def GetMapServiceFilePath(serverName,serverPort,uname,password,serviceName):
    filePath = ""
    try:
        if serverName and serverPort and uname and password:
            # Get a token
            token = getToken(uname, password, serverName, serverPort)
            # Get the root info
            serverURL = "/arcgis/admin/services/"
            # This request only needs the token and the response formatting parameter
            params = urllib.urlencode({'token': token, 'f': 'json'})
            headers = {"Content-type": "application/x-www-form-urlencoded", "Accept": "text/plain"}
            # Connect to URL and post parameters
            httpConn = httplib.HTTPConnection(serverName, serverPort)
            httpConn.request("POST", serverURL, params, headers)
            # Read response
            response = httpConn.getresponse()
            if (response.status != 200):
                httpConn.close()
                print "Could not read folder information."
                return
            else:
                data = response.read()
                # Check that data returned is not an error object
                if not assertJsonSuccess(data):
                    arcpy.AddMessage("Error when reading server information. " + str(data))
                    return
                else:
                    arcpy.AddMessage("Processed server information successfully. Now processing folders...")
                # Deserialize response into Python object
                dataObj = json.loads(data)
                httpConn.close()
                #Store the Folders in a list to loop on
                folders = dataObj["folders"]
                #Remove the System and Utilities folders
                folders.remove("System")
                #folders.remove("Utilities")
                #Add an entry for the root folder
                folders.append("")
                #Loop on the found folders and discover the services and write the service information
                for folder in folders:
                    # Determine if the loop is working on the root folder or not
                    if folder != "":
                        folder += "/"
                    # Build the URL for the current folder
                    folderURL = "/arcgis/admin/services/" + folder
                    httpConn.request("POST", folderURL, params, headers)
                    # Read response
                        httpConn.close()
                        arcpy.AddMessage("Could not read folder information.")
                        return
                    else:
                            arcpy.AddMessage("Error when reading folder information. " + str(data))
                        else:
                            arcpy.AddMessage("Processed folder information successfully. Now processing services...")
                        httpConn.close()
                        # Loop through each service in the folder
                        for item in dataObj['services']:
                            if item["type"] == "MapServer" and str(item["serviceName"]).lower() == serviceName.lower():
                                # Build the Service URL
                                if folder:
                                    sUrl = "/arcgis/admin/services/%s%s.%s" %(folder,item["serviceName"], item["type"])
                                else:
                                    sUrl = "/arcgis/admin/services/%s.%s" %(item["serviceName"], item["type"])
                                # Submit the request to the server
                                httpConn.request("POST", sUrl, params, headers)
                                # Get the response
                                servResponse = httpConn.getresponse()
                                readData = servResponse.read()
                                jsonOBJ = json.loads(readData)
                                # get file path of the service
                                filePath = jsonOBJ["properties"]["filePath"]
                                return filePath
                            else:
                                # Close the connection to the current service
                                httpConn.close()
        else:
        print str(e)
    return filePath
def getToken(username, password, serverName, serverPort):
    # Token URL is typically http://server[:port]/arcgis/admin/generateToken
    tokenURL = "/arcgis/admin/generateToken"
    params = urllib.urlencode({'username': username, 'password': password, 'client': 'requestip', 'f': 'json'})
    httpConn.request("POST", tokenURL, params, headers)
    # Read response
        httpConn.close()
        print "Error while fetching tokens from admin URL. Please check the URL and try again."
        return
    else:
        httpConn.close()
            return
        # Extract the token from it
        token = json.loads(data)
        return token['token']
# A function that checks that the input JSON object
#  is not an error object.
def assertJsonSuccess(data):
    obj = json.loads(data)
    if 'status' in obj and obj['status'] == "error":
        print "Error: JSON object returns an error. " + str(obj)
        return False
    else:
        return True
===============================================================================I hope that helps.
Regards,
Rami.
YousefQuran
Dear Rami,
   Idk what is exactly the case, but I think you should publish a FeatureService in order to access to the data-source from REST. more details
RamiGhali2
Dear Yusuf,
The case is that I want to get the dataset (featureclass) name of a specific featurelayer in a mapservice.
REST doesb't provide these info so, I've created geoprocessing service to do the job by accessing the MXD of the mapservice and get  the dataset name of the requested layers.
Regards,
Rami.
