access jimuMapView from another component
1729
11-18-2022 12:59 PM
LefterisKoumis
Newbie with React.
I have a long code so I split it to different components.
I have the main widget.tsx component and I imported another component PMtoXY to it.
import PMtoXY from "./PMtoXY";
In the widget, I defined the jimuMapView to access the selected map (script below).
In the PMtoXY, I defined a feature layer and want to add it to the map. How do I access the current state of the  jimuMapView in the PMtoXY?
import {
JimuMapViewComponent,
  JimuMapView,
} from "jimu-arcgis";
interface IState {
  jimuMapView: JimuMapView;
state = {
    jimuMapView: null,
activeViewChangeHandler = (jmv: JimuMapView) => {
    if (jmv) {
      this.setState({ jimuMapView: jmv });
 render() {
    return (
      <div className="widget-addLayers jimu-widget p-2">
        {this.props.hasOwnProperty("useMapWidgetIds") &&
          this.props.useMapWidgetIds &&
          this.props.useMapWidgetIds[0] && (
            <JimuMapViewComponent
              useMapWidgetId={this.props.useMapWidgetIds?.[0]}
              onActiveViewChange={this.activeViewChangeHandler}
ReneRubalcava
Esri Frequent Contributor
I am not familiar with ExB or using the jimu framework, but it looks like you can create connections between widgets.
https://developers.arcgis.com/experience-builder/guide/add-widgets/#connect-widgets
There a number of actions that you can use to communicate, but I'm not sure what the best pattern would be for your use case.
https://developers.arcgis.com/experience-builder/guide/action-triggers/
