Access Attribute
1418
09-09-2011 08:51 AM
BrianGustafson
I am doing an Identify task and the results come back fine.  I want to get a single value out of the returned results.  How would I do that?
var segResult = idResult.Graphic;
alert(segResult.attributes[0]);
JeffPace
attributes are a json object.
so if you know the field name, you can do
alert(segResult.attributes["FIELD_NAME"]);
BrianGustafson
That got me on the right track, I also needed to change the property Graphic to feature.  However,  when I get my result it always says undefined.  Is there away to see the raw json returned besides fiddler?  I am using Visual Studio.
JeffPace
I dont use VS, i just use Mozilla and you can alert toSource()
however,
An identify should return a FeatureSet.
so you can do
//featureSet.features returns a Graphics Array
dojo.forEach(featureSet.features, dojo.hitch(this, function(feature){
//each feature is a graphic
//feature.attributes is the json object
alert(feature.attributes["Field_NAME"]);
derekswingley1
You can tweak the URL sent to your service and see the JSON directly in the browser. For instance, the basic identify sample, when you click the map, issues a request like this:  http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer...{%22x%22%3A-9270185.452645523%2C%22y%22%3A5247230.008462553%2C%22spatialReference%22%3A{%22wkid%22%3A102100}}&tolerance=3&returnGeometry=true&mapExtent={%22xmin%22%3A-9270630.93720096%2C%22ymin%22%3A5246864.543921095%2C%22xmax%22%3A-9269675.474347476%2C%22ymax%22%3A5247581.141061208%2C%22spatialReference%22%3A{%22wkid%22%3A102100}}&imageDisplay=800%2C600%2C96&geometryType=esriGeometryPoint&sr=102100&layers=all%3A0%2C2&callback=dojo.io.script.jsonp_dojoIoScript3._jsonpCallback
If you change the f query string parameter to pjson and remove the callback stuff, you get this:  http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer...{%22x%22%3A-9270185.452645523%2C%22y%22%3A5247230.008462553%2C%22spatialReference%22%3A{%22wkid%22%3A102100}}&tolerance=3&returnGeometry=true&mapExtent={%22xmin%22%3A-9270630.93720096%2C%22ymin%22%3A5246864.543921095%2C%22xmax%22%3A-9269675.474347476%2C%22ymax%22%3A5247581.141061208%2C%22spatialReference%22%3A{%22wkid%22%3A102100}}&imageDisplay=800%2C600%2C96&geometryType=esriGeometryPoint&sr=102100&layers=all%3A0%2C2
