Access and Edit Existing Symbol Properties
1891
07-21-2022 07:16 PM
durablesoy
Hi I have rendered a set of Graphics and would like to find out how to access the Graphics properties to modify the existing properties of the Graphics' symbol such as its size and offset value. In other word, modify the properties of the graphic via Javascript after rendering.
MartinPorteš
Hi, I probably have what you are looking for.
Based on some example I created two renderers and on view click the points switch from one to another. I think you should be able to replicate the same thing with graphics layer.
Have a look and good luck!
Martin
<!DOCTYPE html>
<html>
<head>
    <meta charset="utf-8" />
    <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
    <title>
        Visualize all features with the same symbol | Sample | ArcGIS API for JavaScript 4.24
    </title>
    <link rel="stylesheet" href="https://js.arcgis.com/4.24/esri/themes/dark/main.css" />
    <script src="https://js.arcgis.com/4.24/"></script>
    <style>
        html,
        body,
        #viewDiv {
            padding: 0;
            margin: 0;
            height: 100%;
            width: 100%;
            background-color: rgba(15, 15, 15, 1);
    </style>
    <script>
        require([
            "esri/Map",
            "esri/views/MapView",
            "esri/layers/FeatureLayer",
            "esri/widgets/Legend"
        ], (Map, MapView, FeatureLayer, Legend) => {
             * Set up renderer for visualizing all cities with a single symbol
            const citiesRenderer = {
                type: "simple", // autocasts as new SimpleRenderer()
                symbol: {
                    type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
                    color: [255, 0, 255],
                    outline: null
            const citiesRenderer2 = {
                symbol: {
                    color: [0, 255, 255],
                    outline: null
            const citiesLayer = new FeatureLayer({
                url: "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/WorldCities/FeatureServer/0",
                renderer: citiesRenderer,
                definitionExpression: "adm = 'United States of America'"
            // Add the layers to the map
            const map = new Map({
                layers: [citiesLayer]
            const view = new MapView({
                container: "viewDiv",
                map: map,
                extent: {
                    xmin: -3094834,
                    ymin: -44986,
                    xmax: 2752687,
                    ymax: 3271654,
                    spatialReference: {
                        wkid: 5070
                spatialReference: {
                    // NAD_1983_Contiguous_USA_Albers
                    wkid: 5070
            view.on("click", function(event) {
                citiesLayer.renderer = citiesRenderer2
    </script>
</head>
<body>
    <div id="viewDiv"></div>
</body>
</html>
MartinPorteš
Martin
<!DOCTYPE html>
<html>
<head>
    <title>
    </title>
    <style>
        html,
        body,
        #viewDiv {
            padding: 0;
            margin: 0;
            height: 100%;
            width: 100%;
    </style>
    <script>
        require([
            "esri/Map",
                symbol: {
                    outline: null
                symbol: {
                    outline: null
                map: map,
                extent: {
                    xmin: -3094834,
                    ymin: -44986,
                    xmax: 2752687,
                    ymax: 3271654,
                    spatialReference: {
                        wkid: 5070
                spatialReference: {
                    wkid: 5070
    </script>
</head>
<body>
</body>
</html>
durablesoy
Hi Martin, thank you for the advice and code. Cheers!
MartinPorteš
I'm glad I could help. Please accept my post as solution. It should be visible nex to Kudos button or it is in Post Options.
Thank you and have a nice day!
