4.8 Labeling of Polygons
4713
11
08-14-2018 04:42 AM
JamesS1
With the 4.8 API, labeling is now available for points and polygons. I have 10.6.1 installed, webGL enabled, and am consuming a point and polygon feature class as feature layers. The point layer labels just fine, but the polygon layer does not. Am I missing something? I even manually added a labelClass for the polygon layer and it still doesn't work. I can't find any examples of polygons being labeled online with the 4.8 API. Any help is appreciated.
RobertScheitlin__GISP
James,
  Here is a sample that works labeling polygons from my AGOL.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Add labels to a FeatureLayer - 4.8</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.8/esri/themes/light-green/main.css">
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      background-color: black;
  </style>
  <script>
    var dojoConfig = {
      has: {
        "esri-featurelayer-webgl": 1
  </script>
  <script src="https://js.arcgis.com/4.8/"></script>
  <script>
    require([
      "esri/WebMap",
      "esri/views/MapView",
      "esri/layers/FeatureLayer",
      "esri/widgets/Search",
      "dojo/domReady!"
    ], function(WebMap, MapView, FeatureLayer, Search) {
      const labelClass = { // autocasts as new LabelClass()
        symbol: {
          type: "text", // autocasts as new TextSymbol()
          color: "green",
          haloColor: "black",
          font: { // autocast as new Font()
            family: "playfair-display",
            weight: "bold"
        labelPlacement: "above-center",
        labelExpressionInfo: {
          expression: "$feature.TVALUE"
      const view = new MapView({
        container: "viewDiv",
        map: new WebMap({
          portalItem: { // autocasts as new PortalItem
          layers: [
            new FeatureLayer({
              labelingInfo: [labelClass],
              renderer: {
                type: "simple", // autocasts as new SimpleRenderer()
                symbol: {
                  type: "simple-fill", // autocasts as new SimpleFillSymbol()
                  color: "rgba(0,100,0,0.6)",
                  outline: {
                    color: [0, 0, 0, 0.1],
                    width: 0.5
        center: [-85.851, 33.755],
        zoom: 11
      // Adds the search widget to the top right corner of the view
      view.ui.add(new Search({
        view: view
      }), "top-right");
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JamesS1
Yes, I've seen it work with web maps, but I am not using WebMap - I am using Map with the MapView (and ArcGIS Server 10.6.1 for the map service with WebGL enabled). I'd post the code, but it is a complex application with numerous modules and function calls... I will say, however, that my code is very similar to what you have, the WebMap/Map difference aside. If there is some specific code that I could show that would shed some light, I'd be happy to do that.
James,
  OK here is the same sample using a Map and FeatureLayer from a url:
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    var dojoConfig = {
      has: {
  </script>
  <script>
    require([
      "esri/Map",
      "dojo/domReady!"
    ], function(Map, MapView, FeatureLayer, Search) {
        symbol: {
          color: "white",
          haloColor: "black",
            weight: "bold"
      let fLayer = new FeatureLayer({
        url: "https://services3.arcgis.com/XItYIm6b3WFtPaRW/arcgis/rest/services/PolyEditTest/FeatureServer/0",
        outfields: ["*"],
        renderer: {
          symbol: {
            outline: {
              width: 0.5
      let map = new Map({
        basemap: "streets",
        layers:[fLayer]
        map: map,
        zoom: 11
        view: view
      }), "top-right");
  </script>
</head>
<body>
</body>
</html>
JamesS1
There are still differences. You are using a feature service while I am using a map service. My data is in a file geodatabase. Perhaps one of these differences is the reason why my labels aren't displaying for the polygons. Still, the points label fine, so I don't know.
James,
   Are your polygons the same WKID as your basemap?
JamesS1
Yes they are: { wkid: 102100 }
James,
   I see what you mean. I tried adding a polygon layer from my 10.6.1 server and it would not label. You should report this to esri tech support.
JamesS1
Will do. Thanks for the help.
BjornSvensson
Esri Alum
Robert/James, does either one of you happen to have a public layer that it fails with?
For the 10.6.1 layer that it fails with, does it also fail when used in a webmap?
