4.28 sketch visibleElements selectionTools
2474
10-27-2023 09:42 AM
MatthewDriscoll
sketch.visibleElements={selectionTools:{ "lasso-selection": false }}, is not removing the lasso tool from the menu in 4.28.
AnneFitz
Hi @MatthewDriscoll - a fix for this is available on npm @arcgis/core version 4.28.6 and should be available on the CDN this evening. Thanks for letting us know!
AnneFitz
Seems to be working as expected for me - https://codepen.io/annefitz/pen/YzBwWPx?editors=1000
Could you provide a repro case of the issue you're seeing?
MatthewDriscoll
It does seem to work if you use it that way.  Must be a bug in 4.28.  If you take it out and do this it does not.
sketch.visibleElements = ({
      createTools:{
        circle: false,
        rectangle: false,
      selectionTools :{
      creationMode: "update",
      undoRedoMenu: false,
      settingsMenu: false
MatthewDriscoll
Did you have the same results taking it outside the property object of the sketch widget in 4.28?
AnneFitz
Yes, seems like a bug. We are looking into it!
AnneFitz
