4.2 Scene View shortcut keys possible for pan, tilt, and rotate?
2721
01-25-2017 01:37 PM
DavidChrest
Are there shortcut keys available or a way to program shortcut keys to pan, tilt, and rotate the 3D view in a SceneView?
UndralBatsukh
Hi David,
SceneView has out of the box key navigation. Check under the SceneView Navigation section in the following document: SceneView | API Reference | ArcGIS API for JavaScript 4.2
You can also add your own key navigation using SceneView's key-up or key-down events: SceneView | API Reference | ArcGIS API for JavaScript 4.2
Here is a very simple sample that adds key navigation to MapView:
Add keyboard navigation shortcuts | ArcGIS API for JavaScript 4.2
UndralBatsukh
Hi David,
DavidChrest
Ah yes, I see now. Thanks so much!
David
