4.12 LayerList Widget: How to get the ground layers into the list
2122
10-13-2019 09:12 PM
by Anonymous User
Not applicable
Hi, currently the layer list widget is not listing the ground layers. is that an intended behavior of this widget?
Version: 4.12
Ground Layers Count: 1
Ground Layers List Mode: 'show'
thanks!
Tags (1)
Noah-Sager
Currently, we do not have support for ground layers in either the LayerList widget or the BasemapLayerList widget
test-app:
https://codepen.io/noash/pen/LYYNWVo
Noah-Sager
test-app:
by Anonymous User
Not applicable
Thanks for the info. Can you guys please raise an enhancement request, as it would make a sense to support it as it's another type of layer within the map. I thought I could reuse the LayerList Widget for this, but seems like I will have to create my own component for this. Thanks
Noah-Sager
If possible, I would recommend working with Support and getting this properly vetted as an Enhancement request.
https://support.esri.com/en/Products/Developers/web-apis/arcgis-api-for-javascript/
JethroLeevers
@Noah-Sager is the any change on this, it would be useful to be able to toggle terrain on and off in the layer list.
The scene viewer shows the terrain in the layer list.
@Anonymous User what solution did you use?
