4.0: Is there a way to create a WebMap from JSON instead of ArcGIS Online ID?
5716
05-13-2016 01:33 PM
JeffJacobson
Is there a way to create a WebMap using ArcGIS REST API formatted JSON? What I would like to do is construct a map using a webmap defined in a JSON file on the same server as the web application rather than getting the JSON from ArcGIS Online (by providing an AGOL item id corresponding to a webmap).
Obviously, when you construct a WebMap object by providing an AGOL webmap item id, there must be code in the API that is parsing the returned JSON, but I am not finding any documented way to construct a webmap without hosting the map on ArcGIS Online or on a Portal.
KellyHutchins
Esri Notable Contributor
There is a (currently) undocumented fromJSON property on the Web Map that you can use to load a web map from json. Here's a code example showing how it works:
JS Bin - Collaborative JavaScript Debugging
PanagiotisPapadopoulos
first export the Json for your Web map requesting the json with the following url
https://www.arcgis.com/sharing/content/items/4a4d0a1b5c1b4311839fd2c49e27d2b0/data?f=pjson
create webmap parameter
var webmap = {};
add webmap parameter item tag to host the map title
webmap.item = {
          "title":"Map Title",
          "snippet": "web"
add webmap parameter itemData tag to host the JSON data (here place the json downloaded from arcgis online)
webmap.itemData = {
  "operationalLayers": [
      "url": "http://12.18.20.190:6080/arcgis/rest/services/toc/ms_a/MapServer",
      "id": "lvn9638",
      "visibility": false,
      "opacity": 1,
      "title": "layer name"
      "url": "http://192.168.0.19:6080/arcgis/rest/services/toc/ms_a_x/MapServer",
      "id": "nvvf9234",
      "opacity": 1,
  "baseMap": {
    "baseMapLayers": [
{"id":"World_Light_Gray_Base_1486","layerType":"ArcGISTiledMapServiceLayer","opacity":1,"visibility":true,"url":"http://services.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer"},
      {"id":"World_Light_Gray_Reference_4241","layerType":"ArcGISTiledMapServiceLayer","isReference":true,"opacity":1,"visibility":true,"url":"http://services.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Reference/MapServer"}
    "title": "Light Gray"
  "version": "1.9.1",
  "modifyMapAllowed": true
add the webmap parameter during the map creation from the createMap function
mapDeferred = esri.arcgis.utils.createMap(webmap, "map", {
  mapOptions : {
  slider : true,
  nav : false,
  wrapAround180 : true,
  center: [23, 39],
          zoom: 1,
  lods: lods,
  logo: false,
  showAttribution: false
  ignorePopups : false,
  geometryServiceURL : app.geometryServ
sorry this is for 3.16 API.
I just noticed you are asking for 4.0
KellyHutchins
