3.5api, Map created in wrong coordinate system? always 4326
935
07-16-2013 09:53 AM
JeffPace
  map = new esri.Map("map", {
                        autoResize: true,
                     sliderStyle : "large",
          extent: new esri.geometry.Extent({xmin:-9228363.6,ymin:3140074.58,xmax:-9116765.5,ymax:3202141.45,spatialReference:{wkid:102100}})
alert(map.spatialReference.wkid);
returns 4326?????????
I have tried everyway to set it I can.  I have no data or maps in 4326.  This is before any layers are even added.
KenBuja
MVP Esteemed Contributor
When do you call the alert?  Using the following code, the alert says 102100.
require(["esri/map"], function (Map) {
    var map;
    map = new Map("map", {
        basemap: "hybrid",
        autoResize: true,
    map.on("update-end", function(){
JeffPace
    var map;
        basemap: "hybrid",
        autoResize: true,
remove the basemap:"hybrid" line and it no longer works.  That is the problem.  I dont want to specify an esri basemap.
KenBuja
This code gives me the same wkid
    var map;
        autoResize: true,
    var layerDynamic = new esri.layers.ArcGISDynamicMapServiceLayer("http://egisws02.nos.noaa.gov/ArcGIS/rest/services/biogeo/SEFCRI/MapServer")
    map.addLayers([layerDynamic]);
