3.3 api not prompting for login (identitymanager) firefox only.  Chrome and IE work
1885
9
03-13-2013 05:46 AM
JeffPace
Ok so changing my app from 3.2 to 3.3 makes the identity manager stop prompting for a login in FIREFOX (v20 and v19) only.  Chrome and IE7 both work
https://www.mymanatee.org/gisapps/mapviewer-ssl/index.jsp?type=utilitiesinfrastructure  <---- 3.3 api
https://www.mymanatee.org/gisapps/mapviewer/index.jsp?type=utilitiesinfrastructure     <----- 3.2 api
the api is the only change.
any ideas? firefox is our recommended browser
There is no error in the Firebug console other than forbiddens on the urls (expected, since we never logged in)
JeffPace
anyone have similar problems?
TimSeiple
I am experiencing the same in Firefox and Chrome.  However, If i first visit the service directory (e.g. http://host/instance/rest/services), I am prompted and can login successfully.
If I then refresh the webpage i was interested in, the data will appear because the login is valid for the entire browser session.
Obviously not something I want my users to have to do.  Still searching for an elegant solution
Tim
JeffPace
same here, obviously not a solution.
Have not tested 3.4 yet
JeffPace
can't test 3.4 because its not available for download yet.
Anyone else seeing this?
MattLane
Your 3.3 api link is giving me a 404 Page not found error
JeffPace
sorry, redeployed
JeffPace
Same Error with 3.4
Chrome prompts for login, firefox does not
https://www.mymanatee.org/gisapps/mapviewer34/index.jsp?type=utilitiesinfrastructure
JeffJacobson
Same Error with 3.4
I just tried your link in Firefox (v 20) and was prompted for a login.
JeffPace
Believe it or not, I just found and fixed it.
My Draw widget had
dojo.require("dijit.form.CheckBox");
Which was no longer used.  For some reason, it was causing the error.  All I did was comment it our and the login popped up.
Very odd.
