2.9 beta defect - cannot create a WMS layer
2631
9
06-01-2012 09:46 AM
CoreyAlix
Issue can be reproduced on this jsfiddle.
KellyHutchins
Esri Notable Contributor
Looks like this issue is fixed in version 3.0 which will be released later this month.
KellyHutchins
CoreyAlix
Looking forward to 3.0 this June, then.  It does work with 3.0 beta...
http://jsfiddle.net/bEGcp/1/
JeffPace
Thats good news, as we just started using WMS pretty heavily.
side note, and sorry to hijack thread, but has something major changed between 2.8 and 2.9 beta/3.0 beta?
my site works perfectly using
<script type="text/javascript" src="http://servicesbeta.esri.com/jsapi/arcgis/2.8"></script>
but if i use
<script type="text/javascript" src="http://servicesbeta.esri.com/jsapi/arcgis/2.9"></script>
or
<script type="text/javascript" src="http://servicesbeta.esri.com/jsapi/arcgis/3.0"></script>
i get all kinds of errors looking for files locally? such as
http://<localserver>/esri/nls/jsapi_en-us.js
Error: Unable to load ../../esri/nls/jsapi_en-us.js status:404
Line 15
http://<localserver>/<localdirectory>/dojox/gfx/svg.js
http://<localserver>/<localdirectory>/dijit/Dialog.js
NetworkError: 404 Not Found
JeffPace
any ideas?
CoreyAlix
The move from 1.6 to 1.7 is noteworthy...try using the AMD syntax as shown in the jsfiddle above or show me a jsfiddle which doesn't work and maybe I can fix it:
   require ( ["esri/map", "esri/layers/wms"], function () {
      // your code
JeffPace
      // your code
appreicate the response, but i am not even getting to the require statements.  I think it is failing loading the api?
I will see if i can make a simple version reproduce the error.
S_Ector
I'm trying to move to V3.0 and am seeing the same errors as noted in the previous post:
GET http://<myhost>/<mypath>/dojox/gfx/svg.js 404 Not Found
Both cases are looking locally for the file.  Does anyone know of a solution?
JeffPace
you can no longer run files locally, must be run off a webserver.
S_Ector
Thanks.  I removed the baseURL attribute from dojoConfig and it fixed the issues.
